991 : 2011-2019 0
997 : 2004-2012 1
Boxster : 1997- 22
Cayman : 2005- 14
ballcock
1996 Porsche 993 Carrera 2
PostPosted: Wed Jan 30, 2019 7:52 am    Post subject: Hot Oil Pressure Difference After Service Reply with quote
Just a quick note for those who may wish to increase their idle oil pressure once the engine is warm.
My 3.4 was running just above a bar with the oil that was in the car when I purchased it. I can’t know for sure but I believe it had 5W30 a few months before I bought it.
I’ve just had the car serviced with Millers 10W50 , and hot idle is a full bar higher, at just under two bars, the engine definitely runs sweeter and quieter from first turn of the key, but this may be due to the plug and coil pack change also done during the service.
(NOTE, for those of you who are happy with one bar (you know who you are!) I’m not suggesting this will affect logivity etc, but it certainly makes me feel better!)
Ex. '99 996 C2 manual coupe.
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Wed Jan 30, 2019 4:04 pm    Post subject: Reply with quote
Had a very similar experience with my 3.6 on millers 10/50. Not using anything else now!
I will be interested to see how its oil usage compares, not that it used very much.
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Wed Jan 30, 2019 4:26 pm    Post subject: Reply with quote
You put a higher viscosity oil in and you now get higher pressure at idle when warm. Isn't this exactly what you would expect irrespective of the brand of oil used?
asterix_the_gaul
1999 Porsche 996 Carrera 2
PostPosted: Wed Jan 30, 2019 6:39 pm    Post subject: Reply with quote
You also increase pressure by chucking in some more oil, Max oil or a tiny bit more gives you healthier pressures than running oil in middle of the range or below.
PostPosted: Wed Jan 30, 2019 6:45 pm    Post subject: Reply with quote
Beat me to it. Thicker oil = higher pressure.
diverzeusy
PostPosted: Wed Jan 30, 2019 7:18 pm    Post subject: Reply with quote
yep, thicker oil = higher pressure,
and also my logic thinking out loud, if a car has 70/80/90k miles or more on it, then surely a thicker than standard oil is a good thing to take up any minor and normal wear tolerances, or put another way the thin oil is really now too thin for an older engine.?? Dont know
what do you think Thumb
PostPosted: Wed Jan 30, 2019 7:22 pm    Post subject: Reply with quote
Oh no, don't start that.
MisterCorn
It shouldn't do. Unless the extra volume makes it slightly cooler/thicker.
kas750
Reims
2006 Porsche 911
PostPosted: Wed Jan 30, 2019 7:43 pm    Post subject: Reply with quote
Indeed.I would be interested in the theory behind that.
diverzeusy
PostPosted: Wed Jan 30, 2019 8:16 pm    Post subject: Reply with quote
Floor Floor Hand Hand Floor Floor
asterix_the_gaul
PostPosted: Thu Jan 31, 2019 7:10 am    Post subject: Reply with quote
No theory at all, just observation. Dash meter read in the middle, low idle pressure kissing 1bar, topped up oil, overcooked it and dash reads 1 digit over Max and got 1.5bar idle. After last service repeated and got same result.
ballcock
PostPosted: Thu Jan 31, 2019 7:58 am    Post subject: Reply with quote
I can’t think of any scientific law that would agree with the above, not saying it doesn’t happen, I just can’t figure WHY .. unless it’s down to how the pressure gauge or sender operates?
Anyway, my guage is as before, filled to just below max
With regards to higher pressure after the oil change it makes perfect sense to me .. higher hot visosity = higher idle oil pressure. And to be fair I believe I have gone from a W30 to a W50.
It also makes sense to me that the higher hot viscosity will protect higher mileage bearings ... Each to their own tho Razz
MisterCorn
PostPosted: Thu Jan 31, 2019 8:11 am    Post subject: Reply with quote
I tend to agree. The implication from Robertb's post which followed yours was that it was somehow the fact that it was Millers oil which was used which caused the effect, both posts specifically mention the brand. In reality you would see the effect with any brand oil when changing to a thicker oil. I'm not saying that Millers is good or bad, just that it has precious little to do with the change in pressure.
steve1
2002 Porsche 996 Carrera 2
PostPosted: Thu Jan 31, 2019 11:18 am    Post subject: Reply with quote
By using thicker oil you are only increasing the reading on a gauge, the pressure increases in front of the bearings by reducing the flow across them, and reducing the oil throw up the bores.
you have to decide which is best, more flow with thinner oil or less flow with thicker oil.
Just got to wait for an expert now.
2002 996 C2 cab red
Diggermeister
PostPosted: Thu Jan 31, 2019 2:08 pm    Post subject: Reply with quote
I'm confused. What tyres have we decided to run, what oil and how much of it are we putting in them, and what grade of unleaded are we pouring over them?
PostPosted: Thu Jan 31, 2019 2:51 pm    Post subject: Reply with quote
Anything that gets it from A to B quicker Laughing
ballcock
PostPosted: Thu Jan 31, 2019 3:43 pm    Post subject: Reply with quote
Ah right MC! I get your point now. Absolutely NOTHING todo with the brand of oil I put in , that was just a bit of extra (useless) info.
ANY W50 oil would have achieved the same results.
ballcock
PostPosted: Thu Jan 31, 2019 3:47 pm    Post subject: Reply with quote
Yes, good point to an extent, but when you reach the stage where you’re liable to have less than one bar (on the one hot summers day we get in Dublin , stuck in traffic etc) then I would have felt that oil with a thicker HOT viscosity makes good sense.
skinny_monkey
PostPosted: Thu Jan 31, 2019 9:32 pm    Post subject: Reply with quote
You're reading the oil viscosity wrong. The W beings to the first number. Like 0W or 5W
As for higher viscosity causing less flow, the pump sets the flow rate. The higher viscosity just means it has to work harder. But the higher viscosity is what keeps your bearing surfaces apart
