Boxster : 1997- 18
Cayman : 2005- 20
Milo72
PostPosted: Tue Jan 29, 2019 11:21 pm    Post subject: PSE on a Gen 1 Reply with quote
This may sound a stupid question, but how different is the tone between PSE on or off ?
I read in another thread what a great noise it is. I can hear a difference when it’s on but it isn’t huge and it got me wondering if it’s axtually working properly.
997.1 C2S Cab Tip.
tom_nieto
PostPosted: Wed Jan 30, 2019 6:34 am    Post subject: Reply with quote
The difference should be very noticeable... at least it is on mine. At low revs there’s a deep burble with a noticeable pop on the over run compared to PSE off. Can’t vouch for high regs as I always have PSE on and it howls!
Milo72
PostPosted: Wed Jan 30, 2019 8:34 am    Post subject: Reply with quote
I did think it should sound better than it does... I wonder if the valves (?) on the exhaust are sticking.
997.1 C2S Cab Tip.
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Wed Jan 30, 2019 9:00 am    Post subject: Reply with quote
Fairly easy to check that actuators are working ok.
Other possibility is a vacuum leak I think.
Tobyone
PostPosted: Wed Jan 30, 2019 10:13 am    Post subject: Reply with quote
Agreed there is rather a difference between on and off
997.1 C4s GT Silver, factory Aerokit
iainwarner6
PostPosted: Wed Jan 30, 2019 1:17 pm    Post subject: Reply with quote
My friend reported the same issue with his 996 C4S.
We found that the actuators and valves weren't moving fully.
One side freed up just with oil and gentle persuasion, the other side the ball joint on the end of the arm was seized and broke off. We drilled it out and made a new ball from a spare bolt by rounding the head off.
A vacuum leak is certainly another potential cause.
2005 997 C2
resigner
PostPosted: Wed Jan 30, 2019 1:23 pm    Post subject: Reply with quote
Turn it on all the time, isn't it taking a fuse out? mine is, but came like it, love it, makes an amazing sound, especially when parking Smile
