Boxster : 1997- 18
Cayman : 2005- 20
Tobyone
PostPosted: Wed Jan 30, 2019 2:15 pm    Post subject: Reply with quote
Counter Of Beans wrote:
Milo72 wrote:
When it comes to the MOT I’ll attach the plate to the middle grill using plastic wing nuts and bolts.
Ah right, so does it matter if the fixings are, shall we say, bodged for the purposes of MOT day? Are there any MOT rules about how securely the reg plate must be fixed?
And you just peel off the Static Plate, get the car MOT'd, and replace the Static Plate once home, correct?
It must be secure but does not have to be bolted on.
997.1 C4s GT Silver, factory Aerokit
Milo72
PostPosted: Wed Jan 30, 2019 6:20 pm    Post subject: Reply with quote
Yes officer that’s correct....
997.1 C2S Cab Tip.
SGH
2010 Porsche 997 Carrera 4S
PostPosted: Wed Jan 30, 2019 6:59 pm    Post subject: Reply with quote
peterzoom wrote:
What I choose to do is cut the standard plinth down to precisely the correct size for each plate. That way it is a perfect fit, follows the curve of the bumper and gives a degree of protection from those who park by ear!!
I cut the end pieces off the plinth at each end then cut a section out of the remaining ends to give me the exact fit for the plate going on (don't forget to allow for the additional length the end pieces will add when calculating the overall length). Then bond the two ends back on and sand and paint it satin black to finish.
The DVLA guidelines state that there are minimum dimensions for the border of the plate when measured from the outside edge of the characters.
All the information is here ...
www.gov.uk/government/publications/vehicle-registration-numbers-and-number-plates
Here is a picture of before and after.
That's look I wanted Thumb Is that a 13" plate.
Porsche 997.2 Carrera 4S - Carrara White / Cocoa
Defender 300Tdi 110 HCP - Keswick Green
Connect L2 Double Cab - Moondust Silver
VW California Ocean 150PS DSG - Reflex Silver
peterzoom
2001 Porsche 996 Carrera 4
PostPosted: Thu Jan 31, 2019 4:43 pm    Post subject: Reply with quote
Almost, the plate is 13.5 inches and the plinth is 13inches thumbsup
GT3 wheels, hub-centric spacers, brake ducts, Carrera rear wing, 200 cell cats+full big bore system, IPD plenum, K&N cold air intake, Hel lines, V3 sprit booster, Revo re-map, Numeric short shift, Rennline pedals, CSF radiators, Rennline semi-solid engine mounts, Alpine double din dvd, camera and speaker install, IMS Guardian and Zun-Sport grilles
nigel99
2009 Porsche 997 Carrera 2S
PostPosted: Fri Feb 01, 2019 4:17 pm    Post subject: Reply with quote
I've attached my plate to a zunsport grille and brought two grilles so i can choose with or without with a 30 second swap.
Better without though Very Happy
Current: 997.2 C2S, Audi TTS mk3
Previous: Cayman 987.1, Audi TT mk1 , BMW e46
 Filesize:  542.19 KB
 Viewed:  373 Time(s)
AdeD
2010 Porsche 997 Turbo
PostPosted: Fri Feb 01, 2019 5:52 pm    Post subject: Reply with quote
I got a bodyshop to shorten mine, they cut the center section out and plastic welded it back.
997.2 Turbo | 19" HRE's | BBI Cage | Ohlins | H&R Front & Rear ARB's | GT2RS Carbon Seats | DesignLS Custom Retrim | DO88 Intercoolers, Y-Pipe & Inlet Hoses | IPD Plenum | WaterMeth Injection | Equal Length Headers & 3" DeCat Exhaust
 Filesize:  738.57 KB
 Viewed:  349 Time(s)
911TEL
2011 Porsche 997 Turbo S
PostPosted: Sat Feb 02, 2019 6:59 am    Post subject: Reply with quote
Milo72 wrote:
I took mine off completely, had the wholes filled and repainted and bought a short static plate. It’s the way to go.
That's neat …. looks good …. what type of plate is it ?
997 Gen 2 Turbo S Basalt Black -BBS CHR, Kline inconel exhaust, DSC V1 & Polished Bliss air freshener...
SL 55 AMG Obsidian Black
Brompton S2L Black edition
Goto page Previous  1, 2
Page 2 of 2
