991 : 2011-2019 0
997 : 2004-2012 1
Boxster : 1997- 22
Cayman : 2005- 14
SGH
2010 Porsche 997 Carrera 4S
PostPosted: Tue Jan 29, 2019 3:54 pm    Post subject: Front Number Plate Plinth Reply with quote
Anyone know if a short GT3 front number plate plinth will fit 997.2 GTS front bumper ?
Porsche 997.2 Carrera 4S - Carrara White / Cocoa
Defender 300Tdi 110 HCP - Keswick Green
Connect L2 Double Cab - Moondust Silver
VW California Ocean 150PS DSG - Reflex Silver
PostPosted: Tue Jan 29, 2019 4:53 pm    Post subject: Reply with quote
They must do a plinth for the 997.2 GTS , call your OPC there should be 3 types for the GTS they dont actually call it a short plinth they call them plinth for USA spec cars and plinth for Japan spec cars one is short and thin the other is shorter than our stock one but much deeper . they can print off the sizes and you will know which one you need , I am pretty sure it was the USA spec one when I ordered my 997.2 GT3 one that I then couldn't use due to screw holes in the bumper being too wide. Thumb Thumb
Milo72
PostPosted: Tue Jan 29, 2019 5:54 pm    Post subject: Reply with quote
Stupid duplicate
997.1 C2S Tip.
Milo72
PostPosted: Tue Jan 29, 2019 5:55 pm    Post subject: Reply with quote
I took mine off completely, had the wholes filled and repainted and bought a short static plate. It’s the way to go.
997.1 C2S Tip.
 Filesize:  1.17 MB
 Viewed:  1704 Time(s)
SGH
PostPosted: Tue Jan 29, 2019 6:04 pm    Post subject: Reply with quote
My bumper does not need painting, I might just get a shorter plate and remove the plinth
Milo72
PostPosted: Tue Jan 29, 2019 6:10 pm    Post subject: Reply with quote
I hoped for the same when I bought the registration and ordered the shorter plate. I took the plinth off as I was just going to cut it down and saw that the previous owner had used the bumper for target practice, holes everywhere.
Static plates are good though, stay on at all speeds and great to peal off to clean and then put back on.
997.1 C2S Tip.
SGH
PostPosted: Tue Jan 29, 2019 6:12 pm    Post subject: Reply with quote
I looked at Static Plate but wondered if they sit flat on the contour of the bumper behind plinth.
Milo72
PostPosted: Tue Jan 29, 2019 6:22 pm    Post subject: Reply with quote
Don’t know if you can see on mine but it has a slight ripple on the top. I move it around though and had it on the bonnet (looked s**t) Alfa style (looked even worse) and have driven it quite often without it on at all... looks best 😀
Mine is a smaller size, I don’t think a full size would sit flush.
997.1 C2S Tip.
SGH
PostPosted: Tue Jan 29, 2019 6:23 pm    Post subject: Reply with quote
I want to get a shorter plinth to fit shorter plate as my plate is only 5 digit might cut the one I have down to size.
SGH
PostPosted: Tue Jan 29, 2019 6:25 pm    Post subject: Reply with quote
Agree no plate looks better Thumb
Counter Of Beans
PostPosted: Tue Jan 29, 2019 7:35 pm    Post subject: Reply with quote
That plate looks great Milo, but is it road legal? Their website suggests not.
What will happen at MOT time?
I'm Mike and I count beans for a living.
Tobyone
PostPosted: Tue Jan 29, 2019 8:12 pm    Post subject: Reply with quote
yep i did the same, all holes filled and a stick on number plate used.
Just about to have the front end resprayed to get rid of all the stone chips etc.
Looks nice with no front plate on ready to be painted, it would be awful to forget to put a plate back on.
997.1 C4s GT Silver, factory Aerokit
Milo72
PostPosted: Tue Jan 29, 2019 8:14 pm    Post subject: Reply with quote
Not not road legal at all...
When it comes to the MOT I’ll attach the plate to the middle grill using plastic wing nuts and bolts.
997.1 C2S Tip.
Tobyone
PostPosted: Tue Jan 29, 2019 8:29 pm    Post subject: Reply with quote
Similar here, I used those double sided sticky pads to put a proper plate on.
squelch
PostPosted: Tue Jan 29, 2019 9:06 pm    Post subject: Reply with quote
I also have a small plate and ditched the plinth and mounted the plate directly on the PU using the same holes that the plinth used. (I keep a set of standard plates in the car and if I ever get tugged by the law it's a quick "sorry officer I've just been to a show and forgot to swap them back, I'll do it now").
From Stuttgart: 997 GTS, 997 GT3 (Kermit)
From Munich: 535d M Touring
From Bologne: Ducati Superlight
Gone but not forgotten: 996 C4S, 964, 924
 Filesize:  1.1 MB
 Viewed:  1580 Time(s)
chicb
PostPosted: Wed Jan 30, 2019 10:40 am    Post subject: Reply with quote
I have smaller letters, misspaced, totally illegal plates but also have fully legal plates which I put in the boot when going for an Mot. I show them to the tester & he is happy they are in the car as what I do when the car leaves the garage is not their responsibility. Unless the police are sitting at the garage door when I leave there is no come back on them. Granted, not all testers may not have this attitude, but saves a lot of faffing about. Worth asking.
squelch
PostPosted: Wed Jan 30, 2019 11:19 am    Post subject: Reply with quote
Wow - with such an obvious failure and so easily fixed, he's risking his livelihood. It's not the police he needs to worry about - it's when VOSA are sat outside in a totally unmarked car. The MOT testers generally have a "feel" for these things though and will make a call on the day (if there's been a spate of inspections locally he may have insisted on changing the plates before it left).
My mate recently had a VOSA inspection - they sit and watch for a while then literally drive up and block in the last car as he pulls out and tell him to go back in and they basically re-test it. Totally messes up that day's schedule and p1sses off customers who are held up, but of course the reason is "safety first!" He got a warning (absolute bollocking) for a couple of very minor items he missed and when he was telling me about it the next day when I went for an MOT he was virtually still shaking! It really put the willies up him and I'd never seen him do an MOT so thoroughly in my life!
peterzoom
2001 Porsche 996 Carrera 4
PostPosted: Wed Jan 30, 2019 1:28 pm    Post subject: Reply with quote
What I choose to do is cut the standard plinth down to precisely the correct size for each plate. That way it is a perfect fit, follows the curve of the bumper and gives a degree of protection from those who park by ear!!
I cut the end pieces off the plinth at each end then cut a section out of the remaining ends to give me the exact fit for the plate going on (don't forget to allow for the additional length the end pieces will add when calculating the overall length). Then bond the two ends back on and sand and paint it satin black to finish.
The DVLA guidelines state that there are minimum dimensions for the border of the plate when measured from the outside edge of the characters.
All the information is here ...
www.gov.uk/government/publications/vehicle-registration-numbers-and-number-plates
Here is a picture of before and after.
GT3 wheels, hub-centric spacers, brake ducts, Carrera rear wing, 200 cell cats+full big bore system, IPD plenum, K&N cold air intake, Hel lines, V3 sprit booster, Revo re-map, Numeric short shift, Rennline pedals, CSF radiators, Rennline semi-solid engine mounts, Alpine double din dvd, camera and speaker install, IMS Guardian and Zun-Sport grilles
 Filesize:  912.87 KB
 Viewed:  1410 Time(s)
Counter Of Beans
PostPosted: Wed Jan 30, 2019 1:57 pm    Post subject: Reply with quote
Ah right, so does it matter if the fixings are, shall we say, bodged for the purposes of MOT day? Are there any MOT rules about how securely the reg plate must be fixed?
And you just peel off the Static Plate, get the car MOT'd, and replace the Static Plate once home, correct?
Tobyone
PostPosted: Wed Jan 30, 2019 2:14 pm    Post subject: Reply with quote
Park by ear ! Floor Floor Ah funny that made me laugh today that did
