996 : 1997-2005 29
Boxster : 1997- 17
Cayman : 2005- 20
maldren
PostPosted: Wed Jan 30, 2019 1:07 pm    Post subject: Reply with quote
True but I would buy a tub of Ally grease, you can use it in lots of places on the 996 (including the wheel nuts)
Mike
wasz
1999 Porsche 996 Carrera 2
PostPosted: Wed Jan 30, 2019 2:01 pm    Post subject: Reply with quote
Some people have found the bush in aftermarket arms slightly softer than OE too.
There was a thread where a guy with a Turbo replaced his rear arms and noticed the difference under hard acceleration.
Probably won't be noticeable on the fronts, or without turbo power.
Ghianightmare
PostPosted: Wed Jan 30, 2019 2:54 pm    Post subject: Reply with quote
It’s worth remembering that a new bush will always be softer than an old and age hardend bush - so his observations were most likely correct, but he attributed the wrong reason! If he had replaced the arms on his car when it was new, he mightn’t have noticed any difference as the original bushes would have been supple. Question
Just my thoughts...
2002 Seal Grey C4S
skinny_monkey
PostPosted: Thu Jan 31, 2019 9:35 pm    Post subject: Reply with quote
I've just bought meyle. £145 for 2. Plus a couple rear toe arms, Meyle again. Will get them fitted in a few weeks time, looking forward to finally having a solid car again
wasz
PostPosted: Fri Feb 01, 2019 11:52 am    Post subject: Reply with quote
Just my thoughts...
Have a read of "nordicmatter" and later MisterCorn's pictures here:
http://911uk.com/viewtopic.php?t=118256
mmcd87
PostPosted: Fri Feb 01, 2019 1:12 pm    Post subject: Reply with quote
A few helpful threads here: -
http://www.911uk.com/viewtopic.php?p=1104456
http://www.911uk.com/viewtopic.php?p=1321902&sid=6ac1831b87a32e4b7f90664c0188adf6
http://www.boxa.net/forum/topic/76805-suspension-shopping-list-what-am-i-missing/
I have purchased CTE brand all round - to be fitted shortly. The quality looks good. Carparts4less had the full range not long ago.
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Fri Feb 01, 2019 1:48 pm    Post subject: Reply with quote
Do your research on the Spyder arms before you buy, there are some issues with the inner bush sizes. Fine if you buy the complete arm with bushes but they may wear prematurely due to this.
cbriggs1978
PostPosted: Sat Feb 02, 2019 10:04 pm    Post subject: Reply with quote
thanks for the info, the hartech parts guy is on jury duty so will speak to them next week before making any decision.
Should I be replacing the bolts as well or just clean up and re-use original?
infrasilver
Fast & Furious
Fast & Furious
PostPosted: Sat Feb 02, 2019 10:07 pm    Post subject: Reply with quote
If the bolts are fine I would re-use.
cbriggs1978
PostPosted: Mon Feb 04, 2019 8:35 pm    Post subject: Reply with quote
Thanks for the reply (again!)
Goto page Previous  1, 2
Page 2 of 2
