996 : 1997-2005 29
Boxster : 1997- 18
Cayman : 2005- 20
NedHan79
PostPosted: Sun Jan 27, 2019 10:22 pm    Post subject: Seat base restoration Reply with quote
Can the base of a 996 seat be removed without taking the seat out of the car?
My drivers seat has sunken badly, more so on the left and as luck would have it, that’s where I get a lot back and hip pain.
I have found out that for whatever reason, these seats where fitted a few years ago. Condition wise they’re in decent shape except for this. The foam has sunken away down.
On a few quick searches, it may be possible to steam the original foam to put some volume back into it. The leathers quite saggy but I’d imagine if the foam comes up a bit, it’ll help take some shape again. Failing that, it’ll have to be some new sponge.
I have absolutely no experience with this but I’m not afraid to have a go.
Has anyone any experience on this?
I’m hoping to be able to remove the seat base, steam it from below and then treat the leather.
 Filesize:  1.04 MB
 Viewed:  976 Time(s)
PostPosted: Sun Jan 27, 2019 10:29 pm    Post subject: Reply with quote
I'm led to believe (after discussing spraying my hard backs) that if you want to do any work on the seats, it's easier to remove the seat out the car than messing around in the limited space there is.
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Sun Jan 27, 2019 10:37 pm    Post subject: Reply with quote
Takes about 15 minutes to remove a seat so it's not worth the hassle of trying to work on it in the car.
Also the foam bases are interchangeable, I used my slightly worn drivers seat base and changed it with the less worn passengers seat with better bolsters etc.
NedHan79
PostPosted: Sun Jan 27, 2019 10:41 pm    Post subject: Reply with quote
I totally understand that Alex but my problem is limited space. If the seat has to come out, I’ll maybe just go all out and paint the hard backs as well but atm it’s simply a fix to get me comfortable driving the car. Might be a case of taking the seat out and sitting on a milk crate to reverse the car back in. But I’m guessing that’ll have it’s own problems with air bag sensors?
NedHan79
PostPosted: Sun Jan 27, 2019 10:45 pm    Post subject: Reply with quote
Infrasilver are the seat bases all the same? Mine are the wing back ones if that’s a decent term for them and I also think they’re from a boxster as they have strap at the shoulder.
infrasilver
Fast & Furious
Fast & Furious
PostPosted: Sun Jan 27, 2019 11:19 pm    Post subject: Reply with quote
The comfort seat has slightly shallower bolsters (15mm if I remember correctly) than the sports seat. Unsure about the strap on your seat back but I assume this is for the seat belt and wouldn't then be interchangeable.
Your base foam should be able to be swapped between N/S and O/S.
NedHan79
PostPosted: Sun Jan 27, 2019 11:26 pm    Post subject: Reply with quote
I’d be more interested in getting a foam from somewhere else as I don’t want to ruin the passenger seat.
NedHan79
PostPosted: Sun Jan 27, 2019 11:28 pm    Post subject: Reply with quote
Just a random picture. Not my seat but that’s the strap
 Filesize:  1006.67 KB
 Viewed:  908 Time(s)
Hans Gruber
2002 Porsche 996 Carrera 4S
PostPosted: Mon Jan 28, 2019 12:00 am    Post subject: Reply with quote
I had exactly the same issue with my drivers seat, one saggy bum cheek area.
I did take the seat out and noticed that the foam had come away at the sides so I repaired with tie wraps as shown in the pic.
It did the trick and my bad back disappeared along with the noticable dip in the seat
2002 Porsche Carrera 4s
2008 Saab 9-3 Aero ttid - Sold, not arsed
2013 Kawasaki ZX6R - Sold not sorry
2019 Skoda Superb Estate - Bored
 Filesize:  935.68 KB
 Viewed:  889 Time(s)
NedHan79
PostPosted: Mon Jan 28, 2019 12:19 am    Post subject: Reply with quote
The seats not the cause of my back problem as I’ve only had the car a short while but it definitely dosnt help. I’ll give that a go if I can get a chance to look at it Thumb
wasz
1999 Porsche 996 Carrera 2
PostPosted: Mon Jan 28, 2019 10:56 am    Post subject: Reply with quote
You can buy the foam new from OPC
About £55 plus vat or double that with heating element for the sport seats.
But it might be the "cushion carrier" at £22. You might just have to strip the seat down to find out.
NedHan79
PostPosted: Mon Jan 28, 2019 1:54 pm    Post subject: Reply with quote
Ok so I went to take the seat out and didn’t have the correct spline sockets so went to my local motor factory and bought a set. Got home and the rear one was rung so couldn’t get the seat out anyway.
I just flipped the base out with the seat in the car. The canvas below the foam had torn away from the lading edge of the seat so the foam had no support below it. I fed cable ties into it and where it had torn from and also cable ties like the photo above.
While I was at it I got the steamer out and onto the cushion to put some volume back into it.
Fitted it all back together and the cable ties across the base broke immediately. Admittedly I’m not 12 stone and the ties weren’t big enough. The ties holding the canvas are still in place so the seat has some shape and not just a hole where my left cheek sits Very Happy
The leather is badly stretched as god knows how long it’s been like that but atm it’s more of a comfort thing than show winner.
I don’t think there’s much point in doing much with the leather. I’ll give it a spruce up but ultimately I’d like a new base so I’ll keep an eye open.
I’ll try and add photos here if it’ll let me PC
NedHan79
PostPosted: Mon Jan 28, 2019 1:56 pm    Post subject: Reply with quote
Ripped canvas
 Filesize:  1.07 MB
 Viewed:  746 Time(s)
NedHan79
PostPosted: Mon Jan 28, 2019 1:57 pm    Post subject: Reply with quote
Foam hanging out on handbrake side
 Filesize:  1.1 MB
 Viewed:  743 Time(s)
NedHan79
PostPosted: Mon Jan 28, 2019 1:58 pm    Post subject: Reply with quote
Adding a little volume with steam
 Filesize:  1.02 MB
 Viewed:  741 Time(s)
NedHan79
PostPosted: Mon Jan 28, 2019 1:59 pm    Post subject: Reply with quote
Leathers still saggy but at least foam has some shape and support
 Filesize:  1.14 MB
 Viewed:  736 Time(s)
g911omr
PostPosted: Mon Jan 28, 2019 2:28 pm    Post subject: Reply with quote
The seats in my car have sagged a tad. Is removing the base just a case of pulling it up and away from the frame?
NedHan79
PostPosted: Mon Jan 28, 2019 2:38 pm    Post subject: Reply with quote
No but it’s not hard. Look under the front, there’s 2 white clips. Pull the bit Down that sticks out of them and then prise them down from the back. The bit sticking down is like a locking tab to let the rest of the clip move.
Pull out the electric seat adjuster, should slide right off and then just pull the seat up from the front. There’s some wiring underneath so don’t go mad. Just disconnect the plugs to give a little more movement.
My seats are not heated so easy enough.
Just to clarify, mine wasn’t sagging, it was more useless Floor
Time will tell how it goes but it’s better than it was
g911omr
PostPosted: Mon Jan 28, 2019 2:59 pm    Post subject: Reply with quote
Thanks.
I'll give it a go. My car has ruffled leather which wasn't my ideal choice TBH. It just needs a bit of 'plumping up' if you know what I mean. I'd rather change them for standard seats, but finding some has proved more difficult than I thought it would be.
NedHan79
PostPosted: Mon Jan 28, 2019 3:33 pm    Post subject: Reply with quote
Are mine ruffled? I don’t even know. Confused
Ive got a thing for the gt3 jobs but time will tell with my back.
And bank balance Floor
