997 : 2004- 76
964 : 1989-1993 4
Boxster : 1997- 16
Cayman : 2005- 18
k11pol
PostPosted: Sun Jan 27, 2019 6:07 pm    Post subject: 3 scares in one day Reply with quote
I took my gts out today for the first time in the rain and was really disappointed in how badly she handled. She spun out 3 times and once in the dual carriageway in a straight line she just lost it, I thought that was it as it floated from lane to lane before straightening up.
Should it be like this ? It’s got Pirelli’s on just now with about 4mm tread approx all round , would putting a set of Michelin 4s all round make a difference ?
It’s going down to Glasgow to get PPF in a few weeks but I think I need to do something about the handling first as a few stone chips will be the least of my worries.
PostPosted: Sun Jan 27, 2019 6:22 pm    Post subject: Reply with quote
When did you last check your tyre pressures?
Cunno
PostPosted: Sun Jan 27, 2019 6:34 pm    Post subject: Reply with quote
Sound like you hit standing water on the dual carriageway? Wide tyres and standing water never ends well, you need to adjust your driving style in bad condition in a 911 big rubber not a lot of weight pushing them down.
Porsche is for driving not for washing.
Present Car: 2006 3.6 Porsche GT3 997(White)
Ex: 2006 3.4 Porsche Cayman S (Silver)
Ex: 2001 2.7 Porsche Boxster (Seal Grey)
FZP
Paul Ricard
PostPosted: Sun Jan 27, 2019 6:38 pm    Post subject: Reply with quote
It's the first time in the rain ever? When you say it spun out, do you mean that you lost control of the car, or do you mean that the wheels spun up but still kept the car in a straight line.
Is it a 4GTS or GTS. The long and the short of it is that you should still be able to drive it as you would any car in the same conditions.id start with the tyres first and foremost. As Alex states, pressures are an easy check.
Keep in mind the temperatures are below summer tyre temp cut off of 7°C, I'd probably go a little more gently on the right foot you uncover the root cause of your woes.
Although Michelin are a tremendous tyre, I think you've got some homework ahead of you before you need to look at changing tyres
pzero
PostPosted: Sun Jan 27, 2019 6:41 pm    Post subject: Reply with quote
Agree and what was the local temperature?
991.1 Carrera GTS
k11pol
PostPosted: Sun Jan 27, 2019 6:57 pm    Post subject: Reply with quote
The road was wet but not standing water as I’m aware to slow down when I can see water in front of me, I’ve had a 911 for the past 10 years so understand how they drive.
FZP - Yes as post states first time in rain , I bought it in October but not had it out much due to work. Maybe spun out is wrong term it pointed left n slid then right and slid back to left then straightened up. It’s a Gts 2 wheel drive. The tyre pressures are as they should be so as you suggest I think I need to look into it a bit more in depth. It reminded me of a 3 series bmw I owned about 12 years ago, something’s not right.
DucatiRob
PostPosted: Sun Jan 27, 2019 7:16 pm    Post subject: Reply with quote
Sounds like there is something wrong somewhere! Tyre pressures would be the obvious thing, but if they are ok have a really good look at all the condition of all tyres all round! Shouldn't behave like that! I have Michelin PSS that are very good in the wet, not as good as the Potenzas I had before, but when they slide there is plenty feedback and easy to control!
Mercedes CLK DD
Ducati 996
PostPosted: Sun Jan 27, 2019 7:22 pm    Post subject: Reply with quote
I take it you're not relying on what the car says the pressures are. That is only there as a guide.
Could easily have been some diesel on the road or something. Dont know
Cameo
PostPosted: Sun Jan 27, 2019 7:27 pm    Post subject: Reply with quote
Never had any problems in the cold & wet with my 2wd GTS running on Pzeros. Mind you I’m at the opposite end of there UK to you so it doesn’t get as cold. I suspect that might be the problem but check tyre pressures, mine tends to be quite sensitive to minor pressure fluctuations.
Have you got a NA or the new turbo-charged GTS? If the turbo perhaps the extra torque is causing the issue?
991.1 GTS, Guards Red, manual
Cunno
PostPosted: Sun Jan 27, 2019 7:32 pm    Post subject: Reply with quote
Good to know, For reference Michelin 4s are a great tyre in the wet and dry, the best all rounder I've used recently.
k11pol
PostPosted: Sun Jan 27, 2019 7:37 pm    Post subject: Reply with quote
Alex - maybe that’s the problem as I am going by the electronic tyre pressure reading.
Cameo - NA ,All the way,lol
Cunno - I’ve been planning on 4s anyway as had Michelin PS for over a decade on my 911 but thought I would get a few more miles out of the p zeros before changing.
Cameo
PostPosted: Sun Jan 27, 2019 7:51 pm    Post subject: Reply with quote
Good choice Very Happy
I was concerned about two wheel drive and rear engine before I got mine (my first 911) but I’ve been really impressed with traction and handling in all conditions. I hope you get to the bottom of the problem. Thumb
Porsche state the tyres are worn out at 3mm , in Germany i belive that 3mm is the legal limit .
You seems to be close to this .
Tread depth and tyre pressures will effect handleing .
All i can say as a biker .. i Adjust my way of riding in adverse conditions be that rain or snow as i dont slide .. i fall off .
Magic919
PostPosted: Sun Jan 27, 2019 8:01 pm    Post subject: Reply with quote
Minimum tread depth in Germany is 1.6mm like the rest of Europe.
997.2 C2S PDK
997.2 C4S PDK
Rojdog
PostPosted: Sun Jan 27, 2019 8:25 pm    Post subject: Reply with quote
one more thing to consider how old are the tyres? there should be a code on the sidewall.
another Porsche rule is 6 years old and they are worn out no matter tread depth...
PostPosted: Sun Jan 27, 2019 8:47 pm    Post subject: Reply with quote
Ive investigated this further rather than relying on what i have been told .. this seems to answer the question ..
http://www.tyrereviews.co.uk/Article/Should-we-change-tyres-at-3mm.htm
Luddite
PostPosted: Sun Jan 27, 2019 8:55 pm    Post subject: Reply with quote
De Mort... as a biker you have the advantage of smelling the diesel spill before you see it, and of course you will know every pot hole and area of banding, where to avoid white lines and perhaps even tram lines on every road you regularly travel.... Yup perhaps the best lesson for a Porsche driver may be to spend some time on two wheels first...?
K11pol, before I would scrap a set of tyres, date code as mentioned and pressures as suggested, I would take a bit of time to straighten the steering and eyeball the four sidewalls alignment front to back and compare them on both sides of the car, might even grab the top of the wheel and shake the whole car if you are strong enough, perhaps bounce each of the four corners to give a rough check the shockers, or just drive down one of Aberdeen`s cobbled roads, if there are any left, while listening for anything loose... Whatever... hope you get it resolved easily.
Being an old guy I rotate the tyres on my old sports car with it`s even more ancient suspension design and back on the road I feel a difference immediately in that it does not track as it did before the change, taking some time to either I or the car settle into the "new" set up.. Question
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Sun Jan 27, 2019 10:52 pm    Post subject: Reply with quote
Is yours a .1 or .2? I’ve heard of another guy, serial 911 owner who was caught out by his surprisingly turbocharged feeling .2 C2S, and spun it, which he’d never done before. Said it feels a lot snappier.
Johnd52
2011 Porsche Cayman 987
PostPosted: Sun Jan 27, 2019 10:55 pm    Post subject: Reply with quote
Given all the factors above, I suggest that 4mm tread depth is just not enough to do anything but take extreme care in wet and cold conditions. With similarly worn tyres at the end of last summer, I was limited to about 60 mph on a streaming wet motorway. Above that it was virtually undriveable. A new set of boots transformed the car on wet roads.
2015 Cayman GTS. No more PDK but still red.
k11pol
PostPosted: Sun Jan 27, 2019 11:14 pm    Post subject: Reply with quote
An interesting link by De mort on tyre/tread depths.
It’s an N/A so .1 and with it being a GTS the tyres are all less than 6 years old. The date code is something I got caught out with many years ago when I thought I was getting a good deal on a pair of pilot sports so aware of that.
