997 : 2004- 77
996 : 1997-2005 40
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 11
rich07
PostPosted: Sun Jan 27, 2019 4:59 pm    Post subject: alternator refurbishment Reply with quote
Hi guys, the fan belt went on my 94 993 so I decided to refurbish the shroud and fan at the same time, I've removed the unit from the car, separated the shroud, fan and alternator so just searching for a list on the forums of replaceable items for the alternator, there is nothing wrong with it but seems like a good ideal while it's out of the car....help please
the sun is making an appearance here in bournemouth so i'd like to get her back together asap.
thanks Rich
Endoman
PostPosted: Sun Jan 27, 2019 6:18 pm    Post subject: Reply with quote
I only did the voltage regulator, brushes were well worn.
Cameltoe & Heel
PostPosted: Mon Jan 28, 2019 8:51 am    Post subject: Reply with quote
I did he voltage reg and the bearing (worth doing), if your alternator is giving good charge then I say don't bother digging any deeper.
Trev
andyobro
PostPosted: Mon Jan 28, 2019 3:42 pm    Post subject: Reply with quote
I have my fan all apart at the moment for a refresh. I'm considering the RS single pulley conversion to make fan belt replacement easier in the future, the part is a similar cost to the standard bearing and housing.
I know that the alternator is turning a little slower, so less charge, but seeing as I don't use it in the winter when current draw is Max, I'm thinking it will be ok. Wondering if anyone has experience of these?
If this isn't a goer, I'm considering replacing the pulley bearing as not sure of its age. The housing for the bearing is in good condition, so think I should be able to press out the bearing from the housing and replace. The bearing and housing assembly are £100 ish, the bearing would be just a few pounds from my local supplier.
993 Carrera
www.instagram.com/993andy
andyobro
PostPosted: Mon Jan 28, 2019 3:49 pm    Post subject: Reply with quote
PS, I have a suitable puller if you need one Rich.
993 Carrera
Cameltoe & Heel
PostPosted: Mon Jan 28, 2019 4:05 pm    Post subject: Reply with quote
In retrospect I should have looked at this Smile
Trev
cableguy
PostPosted: Mon Jan 28, 2019 4:49 pm    Post subject: Reply with quote
I bought my bearing in the recent group buy. Product and service top notch.
Details here: http://911uk.com/viewtopic.php?t=128412&highlight=alternator+bearing Thumb
C.
Pork!
andyobro
PostPosted: Mon Jan 28, 2019 4:56 pm    Post subject: Reply with quote
C.
Just found that thread, thank you. Have you replaced yours yet? The c clip looks a bitch to remove.
993 Carrera
cableguy
PostPosted: Mon Jan 28, 2019 8:23 pm    Post subject: Reply with quote
C.
Not yet. Will be done in March before annual service.
C.
Pork!
Endoman
PostPosted: Mon Jan 28, 2019 9:49 pm    Post subject: Reply with quote
I've run with an RS pulley for a few years without any problems even in winter with short commutes. Recently changed to the Clewett sytem for no particular reason other than bling.
 Filesize:  89.99 KB
 Viewed:  453 Time(s)
andyobro
PostPosted: Mon Jan 28, 2019 10:18 pm    Post subject: Reply with quote
Love the look, but its a lot of money for the bling isnt it Smile
993 Carrera
