996 : 1997-2005 29
Boxster : 1997- 17
Cayman : 2005- 20
Milo72
PostPosted: Sat Jan 26, 2019 7:25 pm    Post subject: Tiptronic Oil Cooler Replacement... Reply with quote
Anyone done one of these? I wondered if it’s a DIY job or should go to an expert.
With both water and oil going through it i’m a little concerned about fluid levels.
997.1 C2S Cab Tip.
PostPosted: Sat Jan 26, 2019 7:57 pm    Post subject: Reply with quote
It can be done Diy .. a bit messy though and it depends on how corroded the fixings are .. i think from memory they are torx bolts .
You would need to clamp the coolant pipes .
You wont loose much oil but you will on the coolant .. no big deal but airlocks can happen .. rare but possible .
I would tend to disconnect the grey electric valve so that its permanently open to help bleeding it .
At work we use a tester to open it for this part .
At the end of the day i always say if your unsure or not happy then get a garage to do it.
