Boxster : 1997- 18
Cayman : 2005- 20
DucatiRob
PostPosted: Fri Jan 25, 2019 9:16 pm    Post subject: Surprisingly Cheap GT3 Splitter Reply with quote
I was at my local OPC today for a service and thought I would check the price of a new splitter to replace my now wrecked one!, £104 +VAT Surprised I asked them to check as I was sure they were not quoting for the right part and even got the parts guy to check again, but they were adamant this was correct! Cup version, shallower than standard with vents from Motorsport dept, so ordered one on the spot!
Still a little wary of what I might of ordered, will probably end up with a wiper blade or something knowing my luck, but should be here in 10 days so will report back!
Mercedes CLK DD
Ducati 996
Chris_in_the_UK
Estoril
PostPosted: Fri Jan 25, 2019 9:20 pm    Post subject: Reply with quote
Often the case with some of the motorsport parts - cheaper than expected is good though!.
2006 Cayman S PCCB's
kas750
Reims
2006 Porsche 911
PostPosted: Fri Jan 25, 2019 9:28 pm    Post subject: Reply with quote
The cup version on a GT3 is deeper and looks like its made from recycled bin lids, but yes cheaper
DucatiRob
PostPosted: Fri Jan 25, 2019 10:11 pm    Post subject: Reply with quote
I was told it was the shallower version, but will see when it tuns up!
Mercedes CLK DD
Ducati 996
Roro
PostPosted: Fri Jan 25, 2019 10:25 pm    Post subject: Reply with quote
Is yours a track car? I wouldn’t really go for the Cup splitter for a road car, it’s lower than the standard GT3 splitter. Better off spending more for the standard item. Interested to know how you do though. Subscribed Thumb
2007 997.1 GT3
2017 F87 M2
DucatiRob
PostPosted: Fri Jan 25, 2019 10:31 pm    Post subject: Reply with quote
No, not a track car! For the money, I think it's worth a punt, I was going to buy a standard one and shape it a little, maybe wrap it too, not a great finish on any of them so don't mind seeing what I can do with it!
Mercedes CLK DD
Ducati 996
Cunno
PostPosted: Sat Jan 26, 2019 12:09 pm    Post subject: Reply with quote
The cup lip is about 20mm deeper therefore less clearance. I run 1 on mine and normally chew through 2 a year. Lately I’ve been trimming them down a touch with a dremel and home made jig to take about 10mm off does help with clearance. They are a MS part so quality isn’t high on there agenda but a bit of back to back can make a cosmetic improvement.
Link is the part you ordered
https://www.fvd.net/us-en/FVD505997LIP/front-lip-spoiler-9971-gt3-cup-with-air-ducts.html
Porsche is for driving not for washing.
Present Car: 2006 3.6 Porsche GT3 997(White)
Ex: 2006 3.4 Porsche Cayman S (Silver)
Ex: 2001 2.7 Porsche Boxster (Seal Grey)
PostPosted: Sat Jan 26, 2019 3:21 pm    Post subject: Reply with quote
Rob, the cup one is deeper, it also has a more pronounced lip on the corners , similar looking to the aftermarket one that was on your car at Dinslaken but will probably fit better as its OE .but as you say for £100 ish worth a try
there seem to be three lips for the GT/Aero front bumper
The std GT3/Aero one
the cup one with air ducts like you have ordered
a cup one with no air ducts.
I am not sure if both the cup ones are the same depth as each other but they are both deeper than the GT/aero one.
Cunno
PostPosted: Sat Jan 26, 2019 7:52 pm    Post subject: Reply with quote
The only difference between the 2 cup lips is the air ducts the depth is the same, I’ve used both over the years
DucatiRob
PostPosted: Sat Jan 26, 2019 8:22 pm    Post subject: Reply with quote
Cheers chaps Thumb I'm sure you are right, they did assure me that it was the shallower lip, but I'm not convinced! The one on the fvd site looks pretty much the same as the one I have on at the moment, so I am happy to see how I can shape it a little so it's a little less scrapey over speed bumps. The Ohlins will lower the car by a minimum of 20mm so I think I will see what a 15mm trim at the front will look like!
Mercedes CLK DD
Ducati 996
