996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
Swampy
PostPosted: Fri Jan 25, 2019 6:34 pm    Post subject: Air Bag, Below Lower Limit ??? Reply with quote
I had an airbag light on so purchased myself a diagnostic reader (Icarsoft Por 2)
The fault pictured below was shown, all reset and its not reappeared after a short drive.
Does anyone have a clue what it means Dont know
I must admit that only looking at the picture now I have noticed that I only looked at page 1 of 3 Rolling Eyes
Regards Swamps
Swamped By Swampy Smile
 Filesize:  1.19 MB
 Viewed:  509 Time(s)
PostPosted: Fri Jan 25, 2019 7:35 pm    Post subject: Reply with quote
Have you changed the steering wheel recently ?
Have you removed said wheel recently ?
Fault code refers to the airbag in the steering wheel .. it could be the clock spring or the airbag wiring .. never seen this code for an actual airbag fault though .
The airbag has 2 stages for minor and major accident , only one stage has flagged a fault .
My usual experience of this is when the wheel has been removed and the airbag plug has not been refitted properly .. there are a green and an orange plug on the back of the airbag , not sure which is stage 1 though .
Swampy
PostPosted: Fri Jan 25, 2019 7:49 pm    Post subject: Reply with quote
Thanks deMort,
No the steering wheel hasnt been touched in my 20 months of ownership.
The only thing that I have done recently that is out of norm is connect it up to a trickle charger (via the cig connector) as the battery recently died.
Could it be related Dont know
PostPosted: Fri Jan 25, 2019 7:56 pm    Post subject: Reply with quote
Nope.
Code has cleared so monitor it for now .. if the light comes back on i would lean towards the clock spring (the wiring that connects the airbag to the car ) but this is only a hunch and you would need to get it checked out .
Swampy
PostPosted: Fri Jan 25, 2019 11:39 pm    Post subject: Reply with quote
deMort wrote:
Nope.
Many Thanks deMort, one to keep an eye on, the car is still under warranty so if it goes again hopefully it will before it expires at the end of May,provided its covered Dont know
A little sent to help Ruth on her way, my way of saying Thank You for your continued help here at 911uk.... Top Man Smile
