997 : 2004- 74
996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
sday12
PostPosted: Thu Jan 24, 2019 12:30 pm    Post subject: Headlamp Washer Pump Reply with quote
....has expired
Any links to a replacement that isn’t from Porsche at £300?
Part number is 99362450200
Smile
1997 Schwartz Black Manual 993 Carrera 2S Hardbacks/Hollow Spokes + Tequipment goodies
jhrfc
1994 Porsche 993 Carrera 2
PostPosted: Thu Jan 24, 2019 12:45 pm    Post subject: Reply with quote
have you tried unjamming it?
Remove the headlight, then tap the pump with a metal spanner while someone pulls the washer switch.
Mine stopped working (in cold weather) and this did the trick for me, still working 18 months later!
J
Endoman
PostPosted: Thu Jan 24, 2019 12:52 pm    Post subject: Reply with quote
There are several on ebay but you may have to change the plug. There was a plug change on the Porsche part also and the grommet may be different.
I recently changed the one on my 944 for an aftermarket one which works fine.
I did a headlight washer delete so I still have my old one if you get stuck. Evidently Douglas Valley are breaking a 993 targa atmo as well.
sday12
PostPosted: Thu Jan 24, 2019 1:26 pm    Post subject: Reply with quote
Thanks jhrfc, i’ll try that.
Thanks Endoman, i’ll see how I go.
Smile
993tt
PostPosted: Thu Jan 24, 2019 3:41 pm    Post subject: Reply with quote
A few years ago mine packed up, I got a BMW one, under 20 quid, exactly the same accept I had to reverse the 2 wires if I recall correctly.
decgraham
PostPosted: Thu Jan 24, 2019 4:42 pm    Post subject: Re: Headlamp Washer Pump Reply with quote
sday12 wrote:
....has expired
Smile
Don't want to teach my grandmother to suck eggs but you are checking the washer with the headlights on?
ATB Smile
sday12
PostPosted: Thu Jan 24, 2019 4:45 pm    Post subject: Reply with quote
Yup
decgraham
PostPosted: Thu Jan 24, 2019 4:48 pm    Post subject: Reply with quote
sday12 wrote:
Yup
Oh well just thought I'd mention it Thumb
Hope you get it sorted.
ATB Smile
sday12
PostPosted: Fri Jan 25, 2019 4:40 pm    Post subject: Reply with quote
Endoman,
You have a pm.
sday12
PostPosted: Fri Feb 08, 2019 6:58 pm    Post subject: Reply with quote
Ended up getting one for £25 from Type 991:
https://type911shop.co.uk/epages/de867ca1-377e-432e-84fd-bdccf2206766.sf/en_GB/?ObjectID=31701944
It’s acutall the 996 version but with a small kit to make the terminals fit:
https://type911shop.co.uk/epages/de867ca1-377e-432e-84fd-bdccf2206766.sf/en_GB/?ObjectPath=/Shops/de867ca1-377e-432e-84fd-bdccf2206766/Products/3862
Thanks to Endoman for his efforts. Thumb
