996 : 1997-2005 29
Boxster : 1997- 17
Cayman : 2005- 20
AlanPM
2003 Porsche 996 Carrera 4S
PostPosted: Wed Jan 23, 2019 7:38 pm    Post subject: New clutch needed, Sachs or Porsche, Reply with quote
Hi chaps. So new clutch needed soon and looking on Design911 choices are genuine Porsche or Sachs. Has anyone any experience of fitting the Sachs option?, good or bad. It’s getting IMS and RMS at the same time so just trying to budget a bit
2003 911 C4S cabriolet, manual,
Polar Silver with Metropol Blue interior, LTT, SSK, wheel spacers, Design Tech CAI, BMC Sports filter, Remap, RS engine mounts.
2007 BMW 335i M Sport
 Filesize:  925.79 KB
 Viewed:  848 Time(s)
PostPosted: Wed Jan 23, 2019 7:44 pm    Post subject: Reply with quote
I had a Sachs fitted 30k miles/3 years ago. Still going strong. It's a bit wiffy if you give it some stick, ie. hold it on a hill for a minute.
"It's getting IMS & RMS at the same time" - does it not already have them?
AlanPM
PostPosted: Wed Jan 23, 2019 8:21 pm    Post subject: Reply with quote
Hi Alex, yes I do believe it might already have both IMS and RMS !!
However it’s now done 97K and I think it’s time to bullet proof it for another 97K.
PostPosted: Wed Jan 23, 2019 8:44 pm    Post subject: Reply with quote
There's no bullet proof after market option unless going down the rebuild route. Unless you're just thinking of popping the outer seal off and checking for play. Fitting another bearing is just resetting your chance of it blowing up.
willy
PostPosted: Wed Jan 23, 2019 9:34 pm    Post subject: Reply with quote
I went through this in late 2017. There is a thread here:
http://911uk.com/viewtopic.php?t=123906&highlight=
General advice is to consider replacing the flywheel also but it's all in the thread.
To answer your question - I chose Sachs clutch and have no complaints.
1998 996 Carrera Ocean Blue
willy
PostPosted: Wed Jan 23, 2019 9:35 pm    Post subject: Reply with quote
wasz
1999 Porsche 996 Carrera 2
PostPosted: Thu Jan 24, 2019 1:49 pm    Post subject: Reply with quote
I replaced my clutch and flywheel myself.
I used LUK fly and Sachs clutch, on good authority these are the OE suppliers, so same part different box.
Don't buy from design 911
I got clutch fly and a load of other bits under £450 from carparts4less with a black Friday code. They are always doing codes.
Check my link in my sig for the other jobs done with the box out.
peterzoom
2001 Porsche 996 Carrera 4
PostPosted: Thu Jan 24, 2019 5:14 pm    Post subject: Reply with quote
I did the clutch last year and went for LUK items plus a replacement release arm/pin/boot and must say I am very happy with the apparent quality out of the box and feel once fitted.
What I would say is that I also fitted a new clutch slave cylinder and bled the system at the same time.
The removed slave cylinder, although intact and not leaking in way, felt decidedly stiff and notchy, so might be worth considering changing it as well.
GT3 wheels, hub-centric spacers, brake ducts, Carrera rear wing, 200 cell cats+full big bore system, IPD plenum, K&N cold air intake, Hel lines, V3 sprit booster, Revo re-map, Numeric short shift, Rennline pedals, CSF radiators, Rennline semi-solid engine mounts, Alpine double din dvd, camera and speaker install, IMS Guardian and Zun-Sport grilles
wasz
PostPosted: Thu Jan 24, 2019 5:49 pm    Post subject: Reply with quote
Ah yes I did mine too, the plastic end cap had worn away on my slave and was wearing away at the metal arm.
A new one (SACHS ~£60) and the arm and pin has been revised by Porsche to a 997 part to eliminate creaking (OPC ~£100) and my clutch is silky smooth.
