Posted: Wed Jan 23, 2019 11:16 am Post subject: ABS and PSM disco lightshow
We have a bit of snow and ice like most of the country and it seemed like good fun to get the 911 out and play on the sub optimal road surfaces nearby.
Great fun and I would thoroughly recommend it, I had a blast
However there was a recurring oddity in so much that when an enthusiastic bit of wheelspin or slightly sideways motoring occurred The ABS and PSM plus handbrake warning light all lit up and stayed on. However if I stopped and switched the motor off and waited 5 minutes they all went out and stayed out until the next sideways or broken traction moment occurred. Then the same process, switch off wait 5 minutes, switch on, all fine
Question is... Is this normal/usual or is there a hint of a failing sensor/reluctor etc etc??
I have read the car for fault codes and there are none logged at all, which seems strange to me.
Anyone got a clue what might be going on? _________________ GT3 wheels, hub-centric spacers, brake ducts, Carrera rear wing, 200 cell cats+full big bore system, IPD plenum, K&N cold air intake, Hel lines, V3 sprit booster, Revo re-map, Numeric short shift, Rennline pedals, CSF radiators, Rennline semi-solid engine mounts, Alpine double din dvd, camera and speaker install, IMS Guardian and Zun-Sport grilles
bakerboy4s Monza
Joined: 06 Jun 2015 Posts: 229 Location: Staffordshire
Posted: Wed Jan 23, 2019 2:53 pm Post subject:
I think Alex Yates had a play in the snow last winter and he turned off the pasm and abs
I did try it with the electronic assistance all off and it was fine and probably a lot more fun too!
However I am curious as to why the warning lights would all be triggered when the systems were live and be reset with a switch off _________________ GT3 wheels, hub-centric spacers, brake ducts, Carrera rear wing, 200 cell cats+full big bore system, IPD plenum, K&N cold air intake, Hel lines, V3 sprit booster, Revo re-map, Numeric short shift, Rennline pedals, CSF radiators, Rennline semi-solid engine mounts, Alpine double din dvd, camera and speaker install, IMS Guardian and Zun-Sport grilles
deMort Zolder
Posted: Wed Jan 23, 2019 8:04 pm Post subject:
That doesnt sound quite normal to me .. psm cutting in will illuminate to warn you but then should go out .. not need a ign off and on .. and certainly not for 5 mins ..
i would start with a fault code readout .. if there is a fault it will be logged and we can go from there .
No fault codes indicate the car is doing what it thinks is correct .. doesnt mean its correct though .. just means its a harder fault to find as its something failing within the limits . _________________ .
Posted: Wed Jan 23, 2019 9:29 pm Post subject: abs pasm
I had this problem with mine , I did some research and it was the brake light switch on the pedal that failed , cheapest part to start with, replaced that and not had any issues since ,
markv8 Trainee
Posted: Thu Jan 24, 2019 5:25 pm Post subject: Re: abs pasm
Thanks for the info everyone, the brake light switch sounds like a good place to start as I recently had to replace the clutch switch and as they are most likely to be similar vintage it might just be on it's way out like its cousin _________________ GT3 wheels, hub-centric spacers, brake ducts, Carrera rear wing, 200 cell cats+full big bore system, IPD plenum, K&N cold air intake, Hel lines, V3 sprit booster, Revo re-map, Numeric short shift, Rennline pedals, CSF radiators, Rennline semi-solid engine mounts, Alpine double din dvd, camera and speaker install, IMS Guardian and Zun-Sport grilles
