Boxster : 1997- 18
Cayman : 2005- 20
benbuhagiar
2008 Porsche 997 Carrera 2
PostPosted: Tue Jan 22, 2019 9:40 am    Post subject: Wiper blades Reply with quote
Hello
I need new wiper blades, measured them up at 22" and 21", however some online websites suggest they should both be 22".
What would you advise?
997.2 Carrera PDK
FZP
Paul Ricard
PostPosted: Tue Jan 22, 2019 9:44 am    Post subject: Reply with quote
Ben
I'm currently in the same process and looking at the PIAA ones as they seem to get the thumbs up round here. Currently running Bosch. I've downloaded the parts list from their website and the PDF is too hard to read on a mobile phone so not made progress.
The key is the curved blade on the passenger side as mine don't sit properly in the outer edge on the passenger side.
benbuhagiar
PostPosted: Tue Jan 22, 2019 9:49 am    Post subject: Reply with quote
Let me know what you do.
One of mine split this morning, so I need to order some asap.
997.2 Carrera PDK
PostPosted: Tue Jan 22, 2019 10:02 am    Post subject: Reply with quote
22" Bosche Aeros all round including the rear. You can bend the passenger side one to make contact all the way across. GT4 did a write-up on it somewhere.
benbuhagiar
PostPosted: Tue Jan 22, 2019 10:17 am    Post subject: Reply with quote
Thanks. Now ordered.
997.2 Carrera PDK
Martian
2007 Porsche 997 Turbo
PostPosted: Tue Jan 22, 2019 2:26 pm    Post subject: Reply with quote
OE are 22" and 21" curved.
Bosch Aerotwin look a bit aftermarket using the 997 'hooked' arm, raising it higher than the standard Bosch/PIAA etc. I preferred the flatter OE look.
Magic919
PostPosted: Tue Jan 22, 2019 5:00 pm    Post subject: Reply with quote
I use the Bosch 582S set.
997.2 C2S PDK
997.2 C4S PDK
SGH
2010 Porsche 997 Carrera 4S
PostPosted: Tue Jan 22, 2019 5:41 pm    Post subject: Reply with quote
I bought these....
https://www.ebay.co.uk/itm/Bosch-Super-Plus-Front-Wiper-Blades-Set-550-530mm-22-21-Spoiler-3397001582-582S/162703228240?epid=249588289&hash=item25e1de3d50:g:uOkAAOSwm9tZ2UWN:rk:2:pf:0
Porsche 997.2 Carrera 4S - Carrara White / Cocoa
Defender 300Tdi 110 HCP - Keswick Green
Connect L2 Double Cab - Moondust Silver
VW California Ocean 150PS DSG - Reflex Silver
jpsh120
PostPosted: Tue Jan 22, 2019 7:27 pm    Post subject: Reply with quote
Rear is also different. Might be the same size but fitment type is different.
See here;
http://911uk.com/viewtopic.php?p=1205916#1205916
2007 997 Carrera S - SOLD Sad
SGH
PostPosted: Tue Jan 22, 2019 7:50 pm    Post subject: Reply with quote
Is the rear a BOSCH AP21U correct ?
benbuhagiar
PostPosted: Wed Jan 23, 2019 2:42 pm    Post subject: Reply with quote
See here;
Fitted the front two with no issues, went to back and the fitment wasn't right.
Came on here and just seen your post. The back is 100% different. Will need to return Bosch AR22U and order an alternative.
997.2 Carrera PDK
benbuhagiar
PostPosted: Wed Jan 23, 2019 2:45 pm    Post subject: Reply with quote
I've gone for AP22U.
997.2 Carrera PDK
Carrerascott
PostPosted: Wed Jan 23, 2019 6:26 pm    Post subject: Reply with quote
I always use Frazerpart for the OE type Bosch ones - never had a problem
https://www.frazerpart.com/cgi-bin/sh000001.pl?WD=wiper&PN=986_987_Boxster_Cayman_996_997_wiper_blade_set%2d354%2d2%2ehtml#SID=163
997 Carrera S Gen1
NLW73
SGH wrote:
I bought these....
same for me and spot on.
how often do folks change them? annually regardless?
997 C2s Schwarz
Lordturpin
PostPosted: Thu Jan 24, 2019 7:37 am    Post subject: Reply with quote
Bosch 582S every time - £19 delivered from Amazon Smile
997.1 C4
987 S
FZP
Paul Ricard
PostPosted: Thu Jan 24, 2019 8:29 am    Post subject: Reply with quote
NLW73 wrote:
SGH wrote:
I bought these....
The marketing guff says between 6-12 months. I change them when the glass tells me to.
benbuhagiar
PostPosted: Thu Jan 24, 2019 9:17 am    Post subject: Reply with quote
NLW73 wrote:
SGH wrote:
I bought these....
Usually every 3 years. I only do 8k miles a year and use RainX, so don't use my wipers that often.
997.2 Carrera PDK
Diggermeister
PostPosted: Thu Jan 24, 2019 1:25 pm    Post subject: Reply with quote
I put them on my 996 turbo and they were excellent - really did work well. FWIW, as someone else here says, the driver and passenger side blades are different.
However... I tried to order a set for my daily VW Transporter and gave up after twice receiving the wrong type of fitting. Think you're safe with a 996/7 though.
Martian
PostPosted: Thu Jan 24, 2019 5:11 pm    Post subject: Reply with quote
I currently have PIAA, but TBH, haven't noticed any difference to Bosch.
www.manheller.com/racing
