Boxster : 1997- 25
OutofOffice
PostPosted: Mon Jan 21, 2019 10:23 pm    Post subject: High pitch beeping + suspension question Reply with quote
Does anyone happen to know what might cause a high pitch rapid series of beeps when I start my car (but which stops after 2 or 3 seconds). I don’t think it ever does it when the engine is warm, but it definitely does it from cold. It will be checked when it goes for its birthday service in a couple of months...
While I am at it, I got a double pasm/abs failure warning recently while out driving but then that went away so maybe I went through a puddle and cleaned the sensor Dont know
Last, the more fun question: I now have cause to regularly travel a combination of roads that are quite bumpy in places and leave the front end feeling a bit skittish where it really shouldn’t be. I have a 996 turbo on standard suspension (top mounts replaced a couple of years ago). Do I (a) get my suspension set up looked at (b) get some better and if so what or (c) just slow down or man up a bit Rolling Eyes
Cheers!
Hans Gruber
2002 Porsche 996 Carrera 4S
PostPosted: Tue Jan 22, 2019 12:07 am    Post subject: Reply with quote
For heavens sake man don’t slow down, you might as well buy a Kia and some string back driving gloves
By beeps do you mean actual warning beeps like a low oil pressure warning or a spurious engine noise that sounds like a beep?
2002 Porsche Carrera 4s
2008 Saab 9-3 Aero ttid - Sold, not arsed
2013 Kawasaki ZX6R - Sold not sorry
2019 Skoda Superb Estate - Bored
Ghianightmare
PostPosted: Tue Jan 22, 2019 8:04 am    Post subject: Re: High pitch beeping + suspension question Reply with quote
[/quote] Last, the more fun question: I now have cause to regularly travel a combination of roads that are quite bumpy in places and leave the front end feeling a bit skittish where it really shouldn’t be. I have a 996 turbo on standard suspension (top mounts replaced a couple of years ago). Do I (a) get my suspension set up looked at (b) get some better and if so what or (c) just slow down or man up a bit Rolling Eyes
Cheers![/quote]
Get it looked at. Do 4 wheel alignment first. After that consider the age of all of the components. Rubber has an effective working life of about 6 years after which it elasticity goes and it doesn’t do what it is meant to do. Same for tyres.
Dampers have a life of about 40,000 miles.
If you’re various bits are older than the reccomended life, it will negatively impact the handling.
As it’s a turbo, it needs healthy components as the engines power is high and will not have deteriorated at the same rate and now there will potentially be an imbalance between power and handling.
I replaced all of my suspension components over the summer - Hartech rebuilt arms and links and Bilstein B6 dampers. Tyres are 12 months old. The improvement is sublime and the fresh arms made the biggest difference. I replaced them last
2002 Seal Grey C4S
OutofOffice
PostPosted: Tue Jan 22, 2019 4:00 pm    Post subject: Reply with quote
Lol. Right you are, Sir.
It’s definitely not an engine noise. It is coming from the cockpit somewhere. Unfortunately I don’t know what the low oil pressure warning sounds like, but it’s an alarm-type of noise that quickly stops.
OutofOffice
PostPosted: Tue Jan 22, 2019 4:05 pm    Post subject: Re: High pitch beeping + suspension question Reply with quote
Cheers![/quote]
I replaced all of my suspension components over the summer - Hartech rebuilt arms and links and Bilstein B6 dampers. Tyres are 12 months old. The improvement is sublime and the fresh arms made the biggest difference. I replaced them last[/quote]
Thank you, that makes complete sense. I will get it looked at.
Stoo.c
PostPosted: Wed Jan 23, 2019 2:10 pm    Post subject: Reply with quote
Last year I did a refresh on my whole front end which came in at well under £500 for all new components (apart from springs and shocks) and after a basic geometry alignment to factory settings, the car was totally transformed. I did all of the work myself to keep costs down but I would really recommend it - I thought the car drive well before but it just felt amazing. Dont underestimate the gradual deterioration of components - you dont notice it happening until you refresh it.
I'm going to do the rear this summer as well.
02 996 C4S
93 Skyline R33 GTS-t
91 CRX vtec turbo
01 986 Boxster S
OutofOffice
PostPosted: Wed Jan 23, 2019 11:34 pm    Post subject: Reply with quote
Makes sense. Fair play to you. I wouldn’t know where to start!
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Thu Jan 24, 2019 6:31 pm    Post subject: Reply with quote
Beeping I suspect is a tracker, probably linked to PSM failure etc, think that's down to a battery issue too.
I'd get the battery tested and tracker either removed or battery on that changed too.
If you need it, checking centre gravity for suspension assessment and refurb.
caterman
PostPosted: Sun Jan 27, 2019 11:45 am    Post subject: Reply with quote
Mine has an aftermarket tracker and it gives 3/4 beeps a few seconds after start up.
Worried me at the start but if you have a tracker and can identify it, google the instruction manual and see what it says.
OutofOffice
PostPosted: Sun Jan 27, 2019 8:16 pm    Post subject: Reply with quote
Thanks - it does have a tracker. That is exactly what happens when I start it. I have the manual so will take a look...
Cheers for all the replies.
