997 : 2004- 66
996 : 1997-2005 35
964 : 1989-1993 1
Shurv
PostPosted: Sun Jan 20, 2019 5:07 pm    Post subject: New tyres 996 C4S - what are the best ones? Reply with quote
It's the first time since I bought the car 6 years ago that all 4 tyres need replacing at the same time. As such is an opportunity to experiment and try something other than the Conti's I've been running. I have been 100% happy with the Conti's, but life moves on and there may be something better out there. Cost isn't a consideration, I want the best grip and handling, mileage is also down the list of priorities, but I want a consistent tyre, and one good in wet as well as dry. N rated, there's a can of worms, not sure I'm bothered if they are N rated or not. What are you guys running and what feedback would you give?
996 C4S Arctic Silver Black leather
DynoMike
2003 Porsche 996 Turbo
PostPosted: Sun Jan 20, 2019 6:41 pm    Post subject: Reply with quote
Hi Marcus, good to see you're still around these parts.
Tyre-wise, I moved from Bridgestone S02As to Michelin PS2s, but currently thinking of Mich Cup2s.
The Bridgestones have a mega stiff sidewall which gives very good steering feel, but the tread overheats if pushed very hard resulting in a 'flat tyre' feeling. The first time this happened, I honestly thought I had picked up a puncture, but normality resumed as the tyre cooled down.
The PS2s were a good upgrade, less direct steering feel but tons more outright grip, most impressive. Mileage wise, mine return about 6000-7000 for the rears before reaching 3mm, which includes about 3 track days also.
Really want to try Cup2s though......
Mike.
2003 996 Turbo
Previous toy 1974 Mini 1000
Ghianightmare
PostPosted: Sun Jan 20, 2019 8:05 pm    Post subject: Reply with quote
PS 2 N rated for me on my C4S.
However The car behaves much better with fresh suspension links... just about to make a relate three on tyre pressures etc - so comparing tyres without considering the condition of suspension bushes can be very subjective
2002 Seal Grey C4S
s70rjw
PostPosted: Sun Jan 20, 2019 8:07 pm    Post subject: Reply with quote
I upgraded from Michelin PS2 to PS4 a few months ago. Plenty of reviews online found them to be substantially better in most tyre tests than the competition. The this I noticed most was how much better turn in was over the PS2. They're not N rated however, if that bothers you.
997.2 manual
PostPosted: Sun Jan 20, 2019 9:42 pm    Post subject: Reply with quote
I had to go with PS2 as I went N rated.
Will try PS4 (non N rated) nest time so I can compare Judge
Personally think the N rating is bo!!ocks but each to their own and all that Thumb
Ghianightmare
PostPosted: Sun Jan 20, 2019 9:56 pm    Post subject: Reply with quote
My tyre supplier told me that the N has a different side wall stiffness to non N.
2002 Seal Grey C4S
greenson
PostPosted: Sun Jan 20, 2019 10:09 pm    Post subject: Tyres Reply with quote
Just had my second full set of Michelin PS2 N rated - all fresh within date stamp for the grand total of £725 fitted and balanced plus a £50 rebate voucher from Michelin so £675 all in .
Transformed the car !
Looked at Ps4 non N rate but struggled to find sizes for C4S
Try Tyre Medics Hinckley
PostPosted: Sun Jan 20, 2019 10:14 pm    Post subject: Reply with quote
Paid £610 for tyres alone from Black Circles.
greenson
PostPosted: Sun Jan 20, 2019 10:27 pm    Post subject: Tyres Reply with quote
Forgot to add , Free Hunter alignment included in fitment ?
No adjustment required being a regular at CG
INWB
PostPosted: Sun Jan 20, 2019 11:25 pm    Post subject: Reply with quote
After making the mistake of buying Pirelli from the OPC when I first bought my C4S I decided to get it right and buy Michelin PS2's. Much prefer them and only £676.14 (according to the spreadsheet) when I bought them in August from Black Circles.(it took them two attempts at fitting them using the mobile service and so won't use them again - still needed balancing)
2003 Manual 996 C4S Midnight Blue
PostPosted: Mon Jan 21, 2019 7:41 am    Post subject: Reply with quote
Not true. They may have stiffer sidewalls compared to some tyres, but tyre stiffness varies and is spec'd on the side of the tyre (load index number), therefore there are some non N rated as stiff if not stiffer. All N rated means is Porsche have tested and recommend them.
Ghianightmare
PostPosted: Mon Jan 21, 2019 8:18 am    Post subject: Reply with quote
Hi Alex,
I’m not in a position to disagree with you, but one thing I can say is that there seems to be a lack of evidence as to what exactly an N rating is, or isn’t.
There is a post on PHs from a person perporting to work in Michelin (it could be my sister for all I know) stating that N can mean a difference in carcass compound or sidewall.
There are also many posts to say they are the same.
I can’t find any evidence from Michelin to confirm either, but that could be my lack of search skills
2002 Seal Grey C4S
PostPosted: Mon Jan 21, 2019 9:14 am    Post subject: Reply with quote
There's a whole host of threads on the subject of N rated tyres on the 'Wheels and Tyres' sub-forum.
eg .This one which includes bulletins from Porsche.
----> http://911uk.com/viewtopic.php?t=53470&start=0&postdays=0&postorder=asc&highlight=
and this one, which contains answers from an expert at Michelin.
----> http://911uk.com/viewtopic.php?t=92039&start=0&postdays=0&postorder=asc&highlight=
PostPosted: Mon Jan 21, 2019 9:57 am    Post subject: Reply with quote
N just means Porsche have approved them...........for a large back-hander Grin
Bluebird911
PostPosted: Mon Jan 21, 2019 10:20 am    Post subject: Reply with quote
N rated PS2s! Thumb
diverzeusy
PostPosted: Mon Jan 21, 2019 10:25 am    Post subject: Reply with quote
one word, MICHELIN Thumb
Spinner
PostPosted: Sun Feb 03, 2019 1:49 pm    Post subject: Reply with quote
I moved from some 5/6 year old S02A's to Cup 2's and the difference is dramatic even before I have fully bedded them in. This is a 6C4S also.
Drove around at low temperatures in the wet in Jan and were fine, don't worry too much they are 'track tyres' as they seem to have a wide enough operating window for most road conditions.
I went with std sizes of 225/295 but wish I had perhaps upped the front a little.
Am waiting for better weather to really fully experience dry performance but certainly low speed accuracy, response and general feel seem to be really rather good.
James M-S
2009 Porsche 997 Carrera 2
PostPosted: Sun Feb 03, 2019 2:31 pm    Post subject: Reply with quote
Michelin Pilot Sport 4S - far better in the wet than my previous Pirelli Pzero.
Magic919
PostPosted: Sun Feb 03, 2019 2:59 pm    Post subject: Reply with quote
Not possible on standard wheels.
997.2 C4S PDK
James M-S
PostPosted: Sun Feb 03, 2019 10:46 pm    Post subject: Reply with quote
Because it’s a 996 or because it’s a c4s?
What sizes?
