Boxster : 1997- 25
dt4
PostPosted: Sat Jan 19, 2019 7:36 pm    Post subject: Heater / fan not running Reply with quote
Its testing my patience lately lol
The control buttons indicate an increase / decrease in fan speed but no change in air being blown, I guess there is a fuse for the fan?
Are there other known issues to check for?
cheers
PostPosted: Sat Jan 19, 2019 7:39 pm    Post subject: Reply with quote
Im beginning to wonder just what actually works on your car Smile
Sorry !
I would start by wiping out the fan , see if its partially seiezed.
Actually .. remove the pollen filter and see if you can get your hand inside or a screwdriver and flick the fan to see if it moves freely .
Fan first then move onto the electrics is the quickest route .
Can you put what car / year you have in your sig please .. it makes life easier for us when looking in depth .. ie fuses , relays etc Smile
You have probably already mentioned it .. but i have a mind like sieve and answer each question on the fly Smile
dt4
PostPosted: Sat Jan 19, 2019 8:18 pm    Post subject: Reply with quote
Laughing
We are just having a power struggle thats all and the car is showing whose boss
I won the battle with the drop links and exhaust hangers and clamps and now the car is flexing its brakes and fan muscles nooo
PostPosted: Sat Jan 19, 2019 8:22 pm    Post subject: Reply with quote
Floor
i know the feeling ..
Car details please and i can look into the electrical side of it should you require .
dt4
PostPosted: Sat Jan 19, 2019 8:25 pm    Post subject: Reply with quote
1999 C4
I thought I had added it to my signature, Ill try again
1999 996 3.4 C4
1975 914 1.8
2000 986 2.7
PostPosted: Sat Jan 19, 2019 8:36 pm    Post subject: Reply with quote
Excellent ..
C7 / D6 fuses .. there is a relay as per the diagram and a fan resistor .. this only tends to knock out a single speed .
Start with the fan being partially seized .
dt4
PostPosted: Sun Jan 20, 2019 9:06 am    Post subject: Reply with quote
Am I right in thinking you can get to the fan from the top after removing the pollen filter?
1999 996 3.4 C4
1975 914 1.8
2000 986 2.7
PostPosted: Sun Jan 20, 2019 4:38 pm    Post subject: Reply with quote
dt4
PostPosted: Sun Jan 20, 2019 5:02 pm    Post subject: Reply with quote
Sorry, there was a clue there Smile
I should have said where is the pollen filter, a bit of rooting around and i found it and span the fan
It didnt start up straight away as there wasnt anything coming from the vents, I got out of the car to see if was spinning and could see it was. I got back in the car and there was air being blown Dont know
It sounds a bit noisey, not intrusively noisey but noisier than i recall
will see how it goes
on another note, the alternator packed up on Mrs dt4's Merc b class on the way to my mothers and everything shut down over the last couple of miles on the way to her house so we ended up pushing it into the local Shell garage and then abandoning it. I'll have to get my local mechanic to rescue it tomorrow and sort it out.
1999 996 3.4 C4
1975 914 1.8
2000 986 2.7
PostPosted: Sun Jan 20, 2019 6:01 pm    Post subject: Reply with quote
Your really not having a lot of luck atm Sad
My feelings are your blower fan is on its way out so be prepaired to replace it .
Simple job though.
Theres not much you can do when an alternator packs up and you have to drive it.
All you can do is turn off any electrical load but if at night with headlights on then you have about 10 mins before it will die other than that it depends on the charge rate of the battery ( which will probably be low ) , alternators often give a a low charge before they finally die .
maldren
PostPosted: Mon Jan 21, 2019 8:51 am    Post subject: Reply with quote
The heater motor is a standard Audi part, cheap from ECP and if you have a facelift car, it's easy to replace, not much more than removing the glove box.
I bought ECP's cheaper pattern part originally but they had a faulty batch so I changed it for the OEM Valeo part.
Mike
