997 : 2004- 77
996 : 1997-2005 40
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 11
diddy_p
PostPosted: Sat Jan 19, 2019 12:32 pm    Post subject: Front facing passenger toddler seat recommendations? Reply with quote
Hi all
Per the subject, does anyone here have a recommendation with regards to a front facing toddler seat I can put in the front of my 993? Just thought I'd check before I head to halfrauds and buy something
My car is a cabriolet so I have lapbelts in the rear which I don't feel like changing to 3 pointers (unless I can source USDM parts!)
1996 Varioram C4 Cab:
M033 Shocks & Springs, M030 Antiroll bars Front and Rear, New suspension bushes, new hood, leather retrim, Dansk Silencers, Big Ovals, bare metal respray and more... Smile
nickjonesn4
PostPosted: Sat Jan 19, 2019 3:30 pm    Post subject: Re: Front facing passenger toddler seat recommendations? Reply with quote
diddy_p wrote:
Hi all
How old is the toddler. I have a forward facing seat for the rear I bought from a forum member that my 3.5 year old is just.about to outgrow. You would need 3 point belts but it is a great fit.
1996 Carrera 2S Vesuvius Metallic
2016 Golf R
2005 E55K Wagon
mashby
PostPosted: Sat Jan 19, 2019 4:00 pm    Post subject: Reply with quote
I use a Maxi Cosi Rodi SPS but it does require 3 point belts. It fits well in the back of the 993 and would fit the front fine but you'll need to deactivate the passenger airbag somehow.
Age range is 3 1/2 upwards so uses the cars seatbelt for restraint.
1994 993 C2
1974 MGB GTV8 3.5
1980 MGB Roadster 1800 stage 3
nickjonesn4
PostPosted: Sat Jan 19, 2019 4:21 pm    Post subject: Reply with quote
Here it is... Concord Ultimax
http://www.911uk.com/viewtopic.php?t=124391&highlight=concord
I'd be happy to sell it on for what I paid - £40 - for it plus P&P
Just depends what age/size the toddler is. This has been perfect for 2 to 3 1/2 and would work rear facing for babies too
Nick
2016 Golf R
2005 E55K Wagon
diddy_p
PostPosted: Sat Jan 19, 2019 4:55 pm    Post subject: Reply with quote
My daughter has just turned 3 and weighs 13.5kg I have a concord ultimax which would fit perfectly in the back if I had 3 point belts, but instead it's in my merc.
Challenge with the front is the shape of the comfort seats and sort of dip below the headrest section
diddy_p
PostPosted: Sat Jan 19, 2019 4:57 pm    Post subject: Reply with quote
I don't think that the passenger airbag needs deactivating if the seat is front facing?
mashby
PostPosted: Sat Jan 19, 2019 5:11 pm    Post subject: Reply with quote
I've just tried the Rodi in the front seat as I also have the standard comfort seats. I see what you mean about the headrest shape as it holds the back of the seat forwards. I would imagine all seats will have the same issue though. Dont know
1994 993 C2
1974 MGB GTV8 3.5
 Filesize:  156.06 KB
 Viewed:  643 Time(s)
mashby
PostPosted: Sat Jan 19, 2019 5:13 pm    Post subject: Reply with quote
Why did that picture load sideways Dont know
Sorted.
1994 993 C2
1974 MGB GTV8 3.5
nickjonesn4
PostPosted: Sat Jan 19, 2019 5:21 pm    Post subject: Reply with quote
have you git a pic of the rodi in the back seats please? they look like a great option!
2016 Golf R
2005 E55K Wagon
diddy_p
PostPosted: Sat Jan 19, 2019 5:23 pm    Post subject: Reply with quote
Thanks for trying the rodi and sending the pic through, much appreciated...
I'll check the Porsche parts catalogues as there must be a way around this. I think 996 comfort seats are similar in size
nickjonesn4
PostPosted: Sat Jan 19, 2019 5:24 pm    Post subject: Reply with quote
Correct
2016 Golf R
2005 E55K Wagon
mashby
PostPosted: Sat Jan 19, 2019 5:36 pm    Post subject: Reply with quote
nickjonesn4 wrote:
Correct
My mistake
I'll see if I've a picture of the Rodi in the back or if not I'll take one later.
It does fit well although I could do with the extended rear belts now though.
1994 993 C2
1974 MGB GTV8 3.5
nickjonesn4
PostPosted: Sat Jan 19, 2019 5:42 pm    Post subject: Reply with quote
mashby wrote:
nickjonesn4 wrote:
Correct
My mistake
Excellent, thankyou in advance.
2016 Golf R
2005 E55K Wagon
mashby
PostPosted: Sat Jan 19, 2019 6:12 pm    Post subject: Reply with quote
Here you go.
I also find it best to buckle the seat belt into the opposite side. It seems to hold the seat firmer.
1994 993 C2
1974 MGB GTV8 3.5
 Filesize:  428.37 KB
 Viewed:  650 Time(s)
nickjonesn4
PostPosted: Sat Jan 19, 2019 7:17 pm    Post subject: Reply with quote
mashby wrote:
Here you go.
Excellent, do you know which particular Rodi model yours is? Seem to be a few variations
2016 Golf R
2005 E55K Wagon
mashby
PostPosted: Sat Jan 19, 2019 7:20 pm    Post subject: Reply with quote
It's the Rodi SPS
https://www.maxi-cosi.co.uk/gb-en/car-seats/rodi-sps.aspx
1994 993 C2
1974 MGB GTV8 3.5
nickjonesn4
PostPosted: Sat Jan 19, 2019 7:37 pm    Post subject: Reply with quote
mashby wrote:
It's the Rodi SPS
Thanks and apologies to the OP for the hijack
2016 Golf R
2005 E55K Wagon
badlands
PostPosted: Tue Jan 22, 2019 10:38 am    Post subject: Reply with quote
MaxiCosi Rodi Air Protect is also a perfect fit in the back.
Use it for my 4 year old.
https://www.maxi-cosi.co.uk/gb-en/car-seats/rodi-airprotect®.aspx
current: 993 carrera coupe, manual, iris blue, bilstein pss10
ex 964 c4
ex 993 carrera cab
