997 : 2004- 76
Boxster : 1997- 16
Cayman : 2005- 18
H0ME
PostPosted: Sat Jan 19, 2019 10:57 am    Post subject: ACF50 - where? Reply with quote
So I bought some acf50 as while the car is being stored over winter I though it would be good to add some protection. But where should I be putting it? Are there some known spots I should be focused on or is it the sort of thing that I should be spraying everywhere once I drop the undertrays?
1996 993 C2 Tip
K888ETH
PostPosted: Sat Jan 19, 2019 12:27 pm    Post subject: Reply with quote
Pretty much everywhere, but a little goes a long way, you don't need to lay it on until it's dripping and keep it well away from the disks and pads!
Don't go too crazy on the exhaust or engine, as it will smoke a bit as they warm up, but it won't do any harm and it will still provide protection.
997 Turbo
Johnd52
2011 Porsche Cayman 987
PostPosted: Sun Jan 20, 2019 8:11 pm    Post subject: Reply with quote
Just done mine and removed arch liners first and cleaned out the crud. Then sprayed it everywhere I could reach. Hubs were hardest as you need to avoid getting the stuff on the disks, but brake cleaner will remove it if you are a bit over enthusiastic. I did not remove the undertrays as I had done that in the summer. But I did spray into any orrifice I could find.
I do have a well protected garage floor as a result of all the drips etc!
2015 Cayman GTS. No more PDK but still red.
Tobyone
PostPosted: Sun Jan 20, 2019 8:15 pm    Post subject: Reply with quote
I am a bit of a WD40 fan for a general spray over stuff to stop any corrosion
997.1 C4s GT Silver, factory Aerokit
andyobro
PostPosted: Tue Jan 22, 2019 1:42 pm    Post subject: Reply with quote
This is a pretty good test of all the inhibitors.
https://www.youtube.com/watch?v=R5LSxpoqcWo
993 Carrera
www.instagram.com/993andy
PostPosted: Tue Jan 22, 2019 4:38 pm    Post subject: Reply with quote
ACF50 is the mutts nuts Thumb A little goes a long way
cableguy
PostPosted: Tue Jan 22, 2019 6:56 pm    Post subject: Reply with quote
Seems like XCP Rust Blocker is the new King of rust protection... Thumb
Edd China approves!
C.
Pork!
