996 : 1997-2005 29
Boxster : 1997- 17
Cayman : 2005- 20
dt4
PostPosted: Fri Jan 18, 2019 2:22 pm    Post subject: Oil pressure readings with new sender Reply with quote
I have just fitted a new sender as the indications were the old one was duff
The photos show the engine running at temp
The second is engine running warm
The third is engine running cold
The forth is the oil pressure readings at cold with key at position 1
Are the readings in the right sort of range?
 Filesize:  649.35 KB
 Viewed:  878 Time(s)
 Filesize:  677.16 KB
 Viewed:  878 Time(s)
 Filesize:  712.51 KB
 Viewed:  878 Time(s)
 Filesize:  689.12 KB
 Viewed:  878 Time(s)
Stoo.c
PostPosted: Fri Jan 18, 2019 2:49 pm    Post subject: Reply with quote
Given I'm assuming those are at idle, they all appear to be within specified range. I'm not sure mine ever gets quite as low as your 'at temp' pic but there are so many factors to consider like oil viscosity, actual engine temp, oil level etc.
Where does it move to 'at temp' when you're rising up the revs?
02 996 C4S
93 Skyline R33 GTS-t
91 CRX vtec turbo
01 986 Boxster S
dt4
PostPosted: Fri Jan 18, 2019 3:21 pm    Post subject: Reply with quote
I'll check when I go out for a proper drive, I was only pootling around locally to get it up to temp and yes, the readings are all at idle
thanks for the reply
screwy
PostPosted: Fri Jan 18, 2019 6:12 pm    Post subject: Reply with quote
Yes they look "normal" to me.
Mine sits just below 5 when cold. And I don't think I've seen mine quite as low as your "at temp" picture. But all looks good. They seem to vary a little across the model years, and maybe by oil type and exact engine temp.
When up to normal operating temp, mine sits just below 2 at idle and just above 4 under load.
Silver C4S Tiptronic 2003MY
TIPEC Thames Valley Region
PostPosted: Fri Jan 18, 2019 10:19 pm    Post subject: Reply with quote
Your gauge is not that accurate but its close enough .. ign on , engine not running and it should read zero , yours is a bit below that .
Cold running and its a little high .. it shouldnt really go above 5.
warm and at idle and i tend to go with anything above 1 bar is ok .
Different oils make a small difference .
The only way to get an accurate measurement is to fit a seperate oil gauge , which will be calibrated and read that off .
I see no point in this instance , you have a good enough gauge reading.
The oil warning light is the main thing to watch out for .. ive never seen it on a 996 but if that illuminates or ***** then you DO have a low oil pressure fault .
Edit ..
Flick- ers seems to be not allowed .
dt4
PostPosted: Sat Jan 19, 2019 8:58 am    Post subject: Reply with quote
thecarfixer
PostPosted: Sat Jan 19, 2019 9:04 pm    Post subject: Reply with quote
Behaviour echos my car with a 78.8k mile old engine, and 10w50 Millers oil, except the hot idle on mine sits at about 2-2.5 bar on a cold day where the air temperature is lower.
On a 35 degree day last year, it dropped down to 1 bar after a fairly hard B road blast..
