996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
Danbassy
PostPosted: Thu Jan 17, 2019 8:49 pm    Post subject: Cayenne turbo 2010 - what’s this warning light? Reply with quote
Can anyone tell me what this warning means?
Dan
 Filesize:  534.38 KB
 Viewed:  570 Time(s)
PostPosted: Thu Jan 17, 2019 9:35 pm    Post subject: Reply with quote
Question
That it's 24 min's until 1pm Dont know
Danbassy
PostPosted: Fri Jan 18, 2019 6:12 am    Post subject: Reply with quote
Laughing
I’m mean the yellow circle with arrow
Zorro
PostPosted: Fri Jan 18, 2019 9:08 am    Post subject: Reply with quote
Stop/start not operating. I find the stop/start doesn't operate a lot of the time compared to my Mercedes where it is very quick to cut in. Probably because it is an early system and less sensitive. I raised it with Porsche years ago and they said it was normal.
The other thing is that stop/start only works if you keep your foot on the brake.
Cayenne74
PostPosted: Fri Jan 18, 2019 2:59 pm    Post subject: Reply with quote
I had a BMW a few years ago and it used to happen on them if the battery was low. By low I mean if it was very slightly below the parameters of being nearly new. Fast forward about 6 years and said car is still on the same battery and the stop start still doesn't work!
PostPosted: Fri Jan 18, 2019 10:29 pm    Post subject: Reply with quote
Basic reasons why a stop start is inactive other than an actual fault ..
The Auto Start Stop function is not available in the
following situations, for example:
• When Sport mode is activated.
• When PSM is switched off.
• During manoeuvring.
• When AC MAX mode is activated.
• When the “Windshield defrost” function is active.
• At elevations above approx. 9850 ft (3,000 meters).
• After engaging a gear without pressing the clutch pedal
when the engine is automatically stopped.
The Auto Start Stop function is available with limited
functionality in the following situations, for example:
• If the air conditioning or passenger compartment
heating is operated at a high setting or if the defrost
function is running for long periods of time.
• If the charge state of the battery is low.
• On uphill or downhill gradients.
• When vehicle internal test processes are taking place,
for example automatic engine diagnosis.
• In the case of excessively low exterior or battery
temperature.
Low battery charge is about 80% of max charge .. in other words anything less than a very well charged battery will shut it down .
Zorro
PostPosted: Sun Jan 20, 2019 10:28 pm    Post subject: Reply with quote
temperature.
Zorro
PostPosted: Sun Jan 20, 2019 10:30 pm    Post subject: Reply with quote
temperature.
My point exactly.
