997 : 2004- 65
Macan : 2014- 6
cvega
PostPosted: Tue Jan 15, 2019 3:37 pm    Post subject: 996 headlights Reply with quote
is it me, or are they really sh*t??? Compared to my seat or my nissan, that use standard halogen bulbs, they seem like candlelight.
I polished the lenses lately and that improved them, but i still find them super weak.
Any lightbulb / LED recommendations?
2003 996 C2 (Ohlins R&T suspension, Toyosport/Spyder exhaust)
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Tue Jan 15, 2019 4:29 pm    Post subject: Reply with quote
Are they the Litronics or standard halogen?
Even the Litronics in mine seem noticeably less crisp than the LED jobs on my Mercedes CLS, but still much better than the halogen ones which I had on my last 4S.
Don't bother upgrading the halogen bulb, makes only a marginal difference. Better to go with a HID upgrade (although technically an MOT failure, though the ballasts can be well hidden or simply reversed).
eabeukes
1999 Porsche 996 Carrera 2
PostPosted: Tue Jan 15, 2019 4:30 pm    Post subject: Reply with quote
Depends on what you have in there now - theres a lot of love for the Cree H7 type led's, but the NightBreakers are pretty good too.
cvega
PostPosted: Tue Jan 15, 2019 4:40 pm    Post subject: Reply with quote
standard halogen lights.
I might try some nightbreakers.
Mikey P
PostPosted: Tue Jan 15, 2019 9:41 pm    Post subject: Reply with quote
Can anyone recommend any good H7 fit LEDs that work well on the 996, as also find the standard bulbs poor after driving my other more modern car.
911munKy
PostPosted: Wed Jan 16, 2019 12:28 am    Post subject: Reply with quote
I fitted HID’s to mine on high beam (4300k H7R anti glare), take a couple of seconds to warm up when first used then instant afterwards, bloody excellent.
Perfect for fast night country lane blasts, £24 a few 4 years ago.
No problems with MOT testing 2 months ago
2000 C2 996
peterzoom
2001 Porsche 996 Carrera 4
PostPosted: Wed Jan 16, 2019 10:28 am    Post subject: Reply with quote
Last year I fitted new Osram D2S bulbs units to my Litronics.
I chose these ..
D2S OSRAM Night Breaker Laser Xenarc +200% Bulbs - Next Generation (Pair)
from www.autobulbsdirect.co.uk at a cost of £95 for the pair
I had read that these lamps rarely fail but their output does degraded noticeably over time. I felt mine were poor and a bit of a yellow tinge rather than a sharp white light.
What a difference when fitted and sparked up! Much better output, most definitely a far sharper, whiter look also when viewed from outside. The beam pattern was clearly more defined and just over 2 metres longer.
I would judge it a worthwhile maintenance task rather than an 'upgrade' and certainly cheaper and less MOT unfriendly in overall terms
GT3 wheels, hub-centric spacers, brake ducts, Carrera rear wing, 200 cell cats+full big bore system, IPD plenum, K&N cold air intake, Hel lines, V3 sprit booster, Revo re-map, Numeric short shift, Rennline pedals, CSF radiators, Rennline semi-solid engine mounts, Alpine double din dvd, camera and speaker install, IMS Guardian and Zun-Sport grilles
cvega
PostPosted: Wed Jan 16, 2019 10:41 am    Post subject: Reply with quote
I've gone with some ebay LEDs mentioned on a few threads. I'll fit and report back when they arrive.
wasz
PostPosted: Wed Jan 16, 2019 10:54 am    Post subject: Reply with quote
Halogen headlight bulbs age.
These are old cars, if your bulbs are 10 years old they will be putting out much less light than when new.
Also the headlights go opaque - give them a sand back and polish.
I run Philips Xtreme Vision and have no complaints.
bakerboy4s
PostPosted: Wed Jan 16, 2019 1:12 pm    Post subject: Reply with quote
Wasz
are the Xtreme H7 a direct swap or is there wiring/mods to do?
wasz
PostPosted: Wed Jan 16, 2019 2:06 pm    Post subject: Reply with quote
I just plugged them in.
Don't get me wrong - they are not as good as my wife's 2013 Golf headlights, but they are good enough. My driving is typically on low traffic unlit rural roads.
bakerboy4s
PostPosted: Wed Jan 16, 2019 3:56 pm    Post subject: Reply with quote
Thanks, i'll give them a try
demon
PostPosted: Wed Jan 16, 2019 4:00 pm    Post subject: Reply with quote
I chose these ..
Just ordered a pair!
- the state of my litronic bulbs have been at the back of my mind for a while, with me frequently looking at the width of the 'rainbow' spread at the top of the beam whenever its lighting up the wall opposite my garage....
1998 Carrera - Black, no sunroof, manual, cable throttle, IPD plenum, 200 cell x pipe, cargraphic backboxes, Ohlins R&T, LSD, polybushed, Girodisc brakes, custom ("shaved") GT3 RS decklid, 997 sports seats, litronic headlights, RUF wing mirrors, Hartech rebuild, >245,000 miles
Mikey P
PostPosted: Wed Jan 16, 2019 6:38 pm    Post subject: Reply with quote
Thanks look forward to the update, think this is likely the way to go these days if work OK in 996 shaped lights. Will wait to I hear they are OK before buying a set.
kas750
Shanghai
2006 Porsche 911
PostPosted: Wed Jan 16, 2019 6:56 pm    Post subject: Reply with quote
Yes me too.I just worry about the heat that they generate and how this can be dissipated.
911Tip
PostPosted: Wed Jan 16, 2019 7:39 pm    Post subject: Reply with quote
I have the Litronics and found them very dim.
Changed to OSRAM Xenarc Night Breaker Unlimited D2S and improved a bit.
Still need to sand the lenses...
Guywilko
PostPosted: Fri Jan 18, 2019 7:04 am    Post subject: Reply with quote
Sand and polish the lights.
It made a massive difference to mine
maldren
PostPosted: Fri Jan 18, 2019 10:04 am    Post subject: Reply with quote
I tried LEDs in the standard lights, lovely even white light but no hotspot so no range.
With the MOT regs, I worried about after market HIDs so I bought Litronics (2nd hand) at significant expense (facelift lights are seem rarer and more expensive than the earlier lights). One is excellent, bright with good penetration, the other is white but lacks the penetration, both now have new Osram Nightbreakers. The next job is to strip them down and check the focussing lenses inside are clean. Failing that, I guess it must be the ballast, anyone worked on these?
Mike
wasz
PostPosted: Fri Jan 18, 2019 10:43 am    Post subject: Reply with quote
This, and clean the inside!
cvega
PostPosted: Sat Jan 26, 2019 2:44 pm    Post subject: Reply with quote
The nighteye LEDs are a fail. Not only they don't fit inside the housing without making holes in it, they don't come with any retaining clips.
I think i'm gonna go with new nightbreakers and some elbow grease to polish the lamps.
