991 : 2011-2019 0
997 : 2004-2012 0
Boxster : 1997- 22
andyobro
PostPosted: Mon Jan 14, 2019 8:18 pm    Post subject: design911 RS Engine mounts Reply with quote
Evening all,
Has anyone used these replacement RS engine mounts from design911?
https://www.design911.co.uk/fu/prod133853/Engine-Mount-Kit---HD-RS-version-Porsche-964-RS---993-RS/
Good, bad, indifferent?
Thanks Andy
993 Carrera
www.instagram.com/993andy
Endoman
PostPosted: Tue Jan 15, 2019 12:11 pm    Post subject: Reply with quote
Looks like you don't get the bolts and washers so not as cheap as first look.
They are made by Uro on ebay as well for £150 +
Type 911 full kit £250+
Personally I'd stick with OPC supplied.
cableguy
PostPosted: Tue Jan 15, 2019 12:18 pm    Post subject: Reply with quote
Can't comment on the ones listed, however i'd advise getting some recommendations before buying.
I went down the semi-solid route with Wevo mounts as I didn't want too much vibration through the drive train.
Check out Rennlist & Pelican Parts as there are plenty of reviews on various options. Wink
C.
Pork!
crash7
PostPosted: Tue Jan 15, 2019 12:50 pm    Post subject: Reply with quote
I would go with the Porsche items, these are cheap copies of the Porsche items, buy well now and they will last a life-time, assuming that you do modest mileage.
As already mentioned the Porsche mounting hardware is expensive, in particular the bolts, washers and spacers that are required, so once you add these in price stacks up. - There was a genuine Porsche kit of everything required on ebay.
I dont find any really additional nvh with the Porsche items, but they do make a noticeable difference in tightening things up against the original soft mounts.
nickjonesn4
PostPosted: Tue Jan 15, 2019 12:51 pm    Post subject: Re: design911 RS Engine mounts Reply with quote
andyobro wrote:
Evening all,
Thanks Andy
These are good, super quality and tuneable. I'm running the softest ones at the moment.
https://www.design911.co.uk/fu/prod130028/Rennline-Tuneable-Semi-Solid-Engine-Mount--Pair--Porsche-964-993-986-996-987-997/
1996 Carrera 2S Vesuvius Metallic
2016 Golf R
2005 E55K Wagon
jev911uk
PostPosted: Tue Jan 15, 2019 3:23 pm    Post subject: Reply with quote
Ive fitted quite a few sets of the URO ones from type 911:
https://type911shop.co.uk/epages/de867ca1-377e-432e-84fd-bdccf2206766.sf/en_GB/?ObjectPath=/Shops/de867ca1-377e-432e-84fd-bdccf2206766/Products/8447
They are pretty much identical to the genuine ones in terms of casting and if you decide you dont like the firmness of the rubber you could always swap them for some of the 2 part bush options as used in earlier cars.
The watercooled guys seem to like them too.
993Type
PostPosted: Sun Jan 20, 2019 3:21 pm    Post subject: Re: design911 RS Engine mounts Reply with quote
nickjonesn4 wrote:
andyobro wrote:
Evening all,
Thanks Andy
I had the first ones of these that came into the UK around 4 years ago.
They needed returning as the thread didn't run all the way up the mount, since resolved.
They replaced some totally shot C4 mounts while I was doing the chassis legs (the scope of work crept a little).
They came with 3x inserts and the promise of replacement inserts only in the future which made them attractive.
I saw a huge difference but my originals were so bad I've no frame of reference.
I was using a lot of clear dinitrol on the rebuild but keep it away from the mounts as the insert material needs to be clear of wax etc as the mount relies on this to tighten.
