hydraulic lifter replacement with engine in-situ?
pietrzj
19 Mar 2014
309
there is a rennlist post on this, but for some reason the photos are not downloading for me and it is done with the engine out.
Anyone done this job with the engine in?
Is it possible to do the inlet ones in the car? I am assuming the exhaust ones are possible, but don't know - hence the post :)
Jan
Hi Jan, I have problem with some pics on Rennlist, I guess it's down to the browser as when I change device they appear.
I've not changed a lifter so cannot comment I'm afraid, why are you thinking that you require this, what symptoms you having at what mileage?.
Trev
I have started getting a ticking from the lhs rear wheel arch which sounds to me like tappets.
Hello
If you are referring to the tappets, yes , they can be done with the engine in situ. Easier if you can take the plugs out to make the engine turn over by hand when you are doing the job.
Make sure you replace the cam cover gaskets. The ones most likely to fail first are the exhaust which is the lower bank as they get hotter.
Good luck.
124,589
1,441,825
49,017
mapp
