964 : 1989-1993 5
Boxster : 1997- 18
Cayenne : 2003- 3
Macan : 2014- 1
pietrzj
PostPosted: Thu Jan 10, 2019 8:34 pm    Post subject: hydraulic lifter replacement with engine in-situ? Reply with quote
there is a rennlist post on this, but for some reason the photos are not downloading for me and it is done with the engine out.
Anyone done this job with the engine in?
Is it possible to do the inlet ones in the car? I am assuming the exhaust ones are possible, but don't know - hence the post Smile
Jan
Cameltoe & Heel
PostPosted: Fri Jan 11, 2019 9:12 am    Post subject: Reply with quote
Hi Jan, I have problem with some pics on Rennlist, I guess it's down to the browser as when I change device they appear.
I've not changed a lifter so cannot comment I'm afraid, why are you thinking that you require this, what symptoms you having at what mileage?.
Trev
pietrzj
PostPosted: Fri Jan 11, 2019 2:53 pm    Post subject: Reply with quote
I have started getting a ticking from the lhs rear wheel arch which sounds to me like tappets.
Citori
1996 Porsche 993 Carrera 2
PostPosted: Tue Jan 15, 2019 8:27 pm    Post subject: Reply with quote
Hello
If you are referring to the tappets, yes , they can be done with the engine in situ. Easier if you can take the plugs out to make the engine turn over by hand when you are doing the job.
Make sure you replace the cam cover gaskets. The ones most likely to fail first are the exhaust which is the lower bank as they get hotter.
Good luck.
Previously enjoyed Porsche:
1996 C2 Coupe.
1983 911 Carrera Targa Sport.
1981 911SC Sport.
1978 911SC.
1970 911E.
I have CDO. It’s like OCD, but the letters are in alphabetical order, LIKE THEY ARE SUPPOSED TO BE..
Aircooled or nothin....
