996 : 1997-2005 43
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
Simon W
1997 Porsche 993 Carrera 2S
PostPosted: Wed Jan 09, 2019 3:28 pm    Post subject: Broken Key - Advice or Recs pls...! Reply with quote
I have a Golf GTI and one of the keys has snapped off the fob - as per photo... I don't have the broken piece anymore, but I do have the other key from which to make a replacement.
Does anyone know if it's possible to have a new metal key part manufactured and attached to the fob? The dealer wants a crazy number to replace the entire unit. My negligible knowledge on how these things work would suggest it should be fairly easy to produce a replacement key and fit it - and all the coding / electronics should be unaffected because I'm using the original fob.
Any thoughts on if this is possible - and if so - names of Co's that can do this...?
993 C2s Black/Marble (sold)
993 C2s Zenith / Marble (sold)
993 C2s Ocean / Marble (sold)
rabbitstew
PostPosted: Wed Jan 09, 2019 4:07 pm    Post subject: Reply with quote
You can buy blank replacement key fobs from ebay for just a couple of quid. They come with the key blank bit which you have snapped. I would ask a locl lock smith if they can cut the blank to match your spare one, then either swap the metal bits over - or swap the electronics from inside your old one into the shiney new housing.
2008 997.1 Turbo Manual - 585whp thanks to do88 & 9e
2000 Ducati 996
1999 Yamaha R1
1994 Kawasaki ZXR750L2
Simon W
PostPosted: Wed Jan 09, 2019 4:25 pm    Post subject: Reply with quote
Great idea.
Ta!
PostPosted: Wed Jan 09, 2019 4:31 pm    Post subject: Reply with quote
There is a place that you can send a pic of your key to and they will send you a perfect copy in the post Thumb
