996 : 1997-2005 43
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
Gazc2
PostPosted: Tue Jan 08, 2019 8:40 pm    Post subject: Handbrake shoe adjuster stuck ? Reply with quote
So started to put the rear brakes back on I have the adjuster all cleaned and greased etc however when I have put them back the adjuster is catching on the return spring and wont turn with a screwdriver, pretty sure its the right spring having checked my Haynes any tips boys on how to resolve this ? and by the way a replacement spring is £19 Surprised
2007 997 Turbo & 924s in progress
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
 Filesize:  183.86 KB
 Viewed:  270 Time(s)
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Tue Jan 08, 2019 8:48 pm    Post subject: Reply with quote
I suspect that it is quite normal for the adjuster to catch on the return spring, I am sure it does on all cars I have seen. This is what gives is a notchiness to the movements and stops it from rotating of its own free will.
Gazc2
PostPosted: Wed Jan 09, 2019 8:28 am    Post subject: Reply with quote
Cheers MC I will fire the disc on and give it another bash Thumb
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
