964 : 1989-1993 6
Boxster : 1997- 18
Cayman : 2005- 12
Cayenne : 2003- 3
Macan : 2014- 1
Grey996
PostPosted: Tue Jan 08, 2019 9:26 am    Post subject: Drivers door not opening from the outside? Reply with quote
This morning the drivers door wouldn’t open with the outside door handle. Unlocked fine with the central locking and the glass drops when you lift the handle but nothing else. It opened when I went around to the passenger side and opened it from the inside.
I’ve found a post of rennlist that mentioned a circlip but the link to the actually fix was dead.
Any clues?
2002 Porsche 996 C2
cvega
PostPosted: Tue Jan 08, 2019 11:46 am    Post subject: Reply with quote
Take a look at this thread : http://911uk.com/viewtopic.php?p=1392697&highlight=#1392697
The part that failed in my case, was number 9 in this diagram:
Parts list:
Hope this helps!
2003 996 C2
2017 Leaf 30kWh
gone: 2010 335d, 2007 Cayman S, 2008 Civic Type-R, 1992 MR2 Turbo ,1994 MR2 N/A
Grey996
PostPosted: Tue Jan 08, 2019 1:23 pm    Post subject: Reply with quote
Perfect thanks, let’s hope it’s that!
2002 Porsche 996 C2
cvega
PostPosted: Tue Jan 08, 2019 2:40 pm    Post subject: Reply with quote
please please please disconnect the wiring in the door before you start messing with the lock/door handle....
I got my hand trapped by the window for quite some time before i managed to free it, with a nice bruise to show for it
2003 996 C2
2017 Leaf 30kWh
s70rjw
PostPosted: Tue Jan 08, 2019 5:51 pm    Post subject: Reply with quote
I had the same issue on a 997. It was a bolt which had failed and is a common fault according to my specialist who charged £100 including VAT last May.
997.2 manual
Grey996
PostPosted: Tue Jan 08, 2019 8:02 pm    Post subject: Reply with quote
Thanks both
2002 Porsche 996 C2
PostPosted: Tue Jan 08, 2019 8:04 pm    Post subject: Reply with quote
Ill second that .. DO IT !!! There is no roll back / safety function on the downwards operation .. removeing the lock whilst wiring plugged in is the same as holding the key in the lock to raise or lower the windows .. in this case it WILL be lower .
Broken or disconnected rod .. disconnected if it has been worked on previously.
Handle has a micro switch which drops the window but there does need to be a physical connection between the handle and the door lock to work .
Grey996
PostPosted: Mon Feb 11, 2019 7:17 pm    Post subject: Reply with quote
Finally got around to looking at this yesterday and yes it was number 9 that had come out of number 12. It was a job a small handed gynaecologist would have struggled with but I glued it back in with a blob of JB Weld and all seems good.
Thanks for the advise.
2002 Porsche 996 C2
PostPosted: Mon Feb 11, 2019 7:56 pm    Post subject: Reply with quote
The outer part of number 12 is a plastic sleeve .. it slides over number 9 to lock it in place ..
Forgot to mention this before Embarassed
Its normally only in the wrong place if someone has worked on it previously .
Grey996
PostPosted: Mon Feb 11, 2019 9:32 pm    Post subject: Reply with quote
Aha, I didn't suss that bit out. I've left the door card off until I was sure it had worked so I'll try and slide it back over, unless it's all totally gummed up!
2002 Porsche 996 C2
