997 : 2004- 74
996 : 1997-2005 34
Boxster : 1997- 18
Cayman : 2005- 14
goodcoffeecode
PostPosted: Tue Jan 08, 2019 7:54 am    Post subject: Engine struggles to turn over when warm Reply with quote
Hi all,
My 05 C2S starts fine when cold. However, if I, say, drive to the shops it really struggles to turn over when I come to restart it. It sounds like the battery is drained. However, the next day it starts fine again, as if someone has magically refilled the battery overnight. The battery is fairly new.
Thanks,
Chris
jl-c
PostPosted: Tue Jan 08, 2019 8:39 am    Post subject: Re: Engine struggles to turn over when warm Reply with quote
goodcoffeecode wrote:
Hi all,
Thanks,
Chris
Sounds as if you might have the common faulty power lead. Check resistance of leads alternator to battery and starter.
goodcoffeecode
PostPosted: Tue Jan 08, 2019 8:54 am    Post subject: Re: Engine struggles to turn over when warm Reply with quote
Hi all,
Thanks,
Chris
Cool, thanks. Is it a simple fix or a Porsche specialist visit?
jl-c
PostPosted: Tue Jan 08, 2019 9:00 am    Post subject: Re: Engine struggles to turn over when warm Reply with quote
Hi all,
Thanks,
Chris
Unfortunately a simple fix but loads of hours to achieve. I think you will find a diy on Rennlist may even be on here, have a search.
Hotpot
PostPosted: Tue Jan 08, 2019 9:27 am    Post subject: Reply with quote
As said, faulty power lead. Had mine replaced last year because of same symptoms.
D5RSR
PostPosted: Tue Jan 08, 2019 10:46 am    Post subject: Cable Reply with quote
Same symptoms as mine, changed the cable and its fine now.
DIY possible but a bit fiddly.
There's a link to RENNLIST DIY in here:
http://www.911uk.com/viewtopic.php?t=128080&highlight=
Darren
997.1 C2S
Leeds
PostPosted: Tue Jan 08, 2019 7:01 pm    Post subject: Reply with quote
There are a few things it can be .. but this lead is the usual cause .
If your car is a manual then its about 4 hours labour + parts ..
If yours is a Tiptronic then its an engine drop im afraid .
I would tend to take off the throttle houseing and look at the lead at the back of the starter .. it tends to melt the plastic insulation if its this.
Job entails ..
Air box off , alternator out , a/c compressor out then just undo it and try and feed it around the many obsticles that are in the way.
Its connected bottom end on the o/s/r of the gearbox .
