996 : 1997-2005 43
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
daborg
PostPosted: Sun Jan 06, 2019 10:16 pm    Post subject: Fuel Gauge Reply with quote
I ran my 996 TT to the lowest fuel level yet < 30miles range.
Afterwards, what was a perfectly working fuel gauge has stopped working. Neither the digital or analogue readings are showing the correct fuel level.
Any ideas on a simple way to rectify this?
asterix_the_gaul
1999 Porsche 996 Carrera 2
PostPosted: Sun Jan 06, 2019 10:28 pm    Post subject: Reply with quote
I take it you refilled with fuel? A full tank or a part fill? How much exactly did you put in
PostPosted: Sun Jan 06, 2019 10:29 pm    Post subject: Re: Fuel Gauge Reply with quote
Did you refill with about £30 worth of fuel Dont know
bakerboy4s
PostPosted: Sun Jan 06, 2019 10:30 pm    Post subject: Reply with quote
Did you put a god dose in? Allowed mine to go very low once put in £30 and no register on gauge, added another £30 and all good.
PostPosted: Sun Jan 06, 2019 10:32 pm    Post subject: Reply with quote
Guess we all posted at the same time...all thinking the same thing Grin
I hope so anyway Thumb
pzero
PostPosted: Sun Jan 06, 2019 10:50 pm    Post subject: Reply with quote
http://www.911uk.com/viewtopic.php?t=89198&postdays=0&postorder=asc&start=0&sid=3282765d62063adf69b4aad7b45d0bdf
991.1 Carrera GTS
sp1ke
PostPosted: Sun Jan 06, 2019 10:56 pm    Post subject: Reply with quote
I don't have my owners manual to hand right now, but I'm pretty sure it mentions this is expected behaviour if you let it run very low before refuelling.
If you filled a full tank, you may just need to start the car again to let it register the correct amount. If you didn't get a tank full, then as other suggested, you may need to top up a bit more & then restart a second time, at which point it should register the correct amount. If not you may have another issue.
Ghianightmare
PostPosted: Sun Jan 06, 2019 11:30 pm    Post subject: Reply with quote
The OP hasn’t said that he put fuel in...
2002 Seal Grey C4S
PostPosted: Sun Jan 06, 2019 11:38 pm    Post subject: Reply with quote
He did say "afterwards" which definitely implies that he did something after running it down to <30 miles range.
It's a Turbo, so 4wd, so the answer is 99% going to be (as previously linked by pzero) to fill the tank up.
See here ---> http://www.911uk.com/viewtopic.php?t=89198&start=0&postdays=0&postorder=asc&highlight=
PostPosted: Mon Jan 07, 2019 7:34 pm    Post subject: Reply with quote
Cough .. put more than £25 of fuel in it Cough .. im sorry .. i have a cold .
daborg
PostPosted: Wed Jan 09, 2019 9:45 am    Post subject: Reply with quote
Ahem... as many of you seem to suspect, I was a tightwad and put in exactly £30 worth of fuel.
I did wonder if filling it to the brim would rectify. Thanks all for the responses. Will give it a go and revert if no change.
PostPosted: Wed Jan 09, 2019 4:34 pm    Post subject: Reply with quote
There will not be a need to revert Grin
wack
PostPosted: Wed Jan 09, 2019 8:33 pm    Post subject: Reply with quote
On the off chance that doesnt fix it then re post please .. but i think it will .
reason .. i had a customer who said he always put £25 of fuel in and the gauge worked and now it doesnt .. i ripped the system appart , replaced and rewired .. turned out the cost of fuel had gone up and it wasnt enough going into the tank to get past the calculated amount .
PostPosted: Wed Jan 09, 2019 9:30 pm    Post subject: Reply with quote
deMort wrote:
..... .. i had a customer who said he always put £25 of fuel in and the gauge worked and now it doesnt .. i ripped the system appart , replaced and rewired .. turned out the cost of fuel had gone up and it wasnt enough going into the tank to get past the calculated amount .
Floor
