996 : 1997-2005 43
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
bobi61
PostPosted: Sun Jan 06, 2019 7:38 pm    Post subject: Jacking Points Reply with quote
Well I have ordered new coil packs , new heat shields and spark plugs to fix my intermittent poor start ups and lumpy running, my local indie says that its defo a coil pack on its way out !!! . I intend to put the car on axil stands and work with the back wheels removed. I just need a bit of advice on getting the car onto the axil stands ??
Shanghai
PostPosted: Sun Jan 06, 2019 8:49 pm    Post subject: Reply with quote
No easy way on a modern Porsche, see thread here http://911uk.com/viewtopic.php?t=131512
The problem is obviously only 4 jack points, so anything other than jackpoint jackstands, rennstands etc is going to be a bit Heath Robinson.
Two great cant fail business ideas in the UK, jackstands AKA jackpoint jackstands and refurbing Ceramic brakes Thumb
991 C2S X51 powerkit PDK in racing yellow, PCCB, PDCC, PSE, Sports design kit, ducktail.
EX 997.2 Carrera 4S PDK
EX 997.2 Carrera S PDK
EX 997 C2 gen 2 PDK
EX 993 Targa
EX 993 Carrera 4 manual
EX 996 3.4 Cabriolet
Luddite
PostPosted: Sun Jan 06, 2019 9:21 pm    Post subject: Reply with quote
You might consider this system.
https://www.holden.co.uk/displayproductEZcarlift.asp
NickHappy
PostPosted: Sun Jan 06, 2019 9:33 pm    Post subject: Reply with quote
I’ve recently had mine up on the stands and it’s pretty straight forward:
Jack up drivers side rear JP first and this will lift the the entire drivers side. Place 1st Axle stand under front JP, release down and then jack up via rear sub frame on same side to then place Axle stand under rear JP on drivers side.
One side on stands
Next repeat on near side and job done.
nb. Proceed with caution and always make sure steady and secure via the shake test at all times
997 turbo Manual.
996 turbo Manual. ex.
PostPosted: Sun Jan 06, 2019 9:42 pm    Post subject: Reply with quote
I swear that's the only Lapis blue 997T in the world!!! worship
Cool
jl-c
PostPosted: Sun Jan 06, 2019 10:38 pm    Post subject: Reply with quote
you may care to take a look here https://surfacetransforms.com
Shanghai
PostPosted: Mon Jan 07, 2019 5:59 am    Post subject: Reply with quote
For
Lol yes well aware of surface transforms but not refurbs? those scouse scallys, Ken Dodd and all that Grin
EX 997 C2 gen 2 PDK
EX 993 Targa
mick43
PostPosted: Mon Jan 07, 2019 1:44 pm    Post subject: Reply with quote
One side on stands
Very useful Nick - thanks.
Please can you point out /describe rear sub frame jack location (apologies if it's obvious once you are under car - which I haven't done yet - but I want this knowledge to hand). Thanks
2005 997 C2S
Sport Chassis. LSD.
jl-c
PostPosted: Mon Jan 07, 2019 3:00 pm    Post subject: Reply with quote
If you look under the chassis rails there are four oval (ish) holes, your jacking pads fit in these, then you jack on the pad (think hockey puck with locating pin) you can buy the jacking adaptors on ebay. Search Porsche jacking pads.
chaser
2005 Porsche 997 Carrera 4S
PostPosted: Mon Jan 07, 2019 6:54 pm    Post subject: Reply with quote
Get the aluminium ones, not the faux carbon variety nooo
997.2 Turbo `10
997.1 C4S `05
996 C2 `02
NickHappy
PostPosted: Mon Jan 07, 2019 8:04 pm    Post subject: Reply with quote
One side on stands
This should help you out Thumb
https://rennlist.com/how-tos/a/porsche-997-how-to-jack-up-your-997-376025
997 turbo Manual.
Spike
PostPosted: Mon Jan 07, 2019 9:01 pm    Post subject: Reply with quote
I have mine on stands now and used this exact method.
Here you can see the front wheel in the air when jacking on the rear jacking point.
2007 997.1 C4S Cabrio
 Filesize:  840.39 KB
 Viewed:  810 Time(s)
MovieStar99
PostPosted: Sat Jan 12, 2019 8:52 pm    Post subject: Reply with quote
The aluminium ones scratch the paint of the jacking points which I have found to my horror much better of with hard rubber ones that lock:
https://www.ebay.co.uk/itm/Porsche-911-964-993-996-997-991-Boxster-Cayman-Jack-Pad-Jacking-Rubber-classic/283219739590?hash=item41f13643c6:g:lhoAAOSwIDJbyuow
jl-c
PostPosted: Sat Jan 12, 2019 9:03 pm    Post subject: Reply with quote
I would agree.
mick43
PostPosted: Mon Jan 14, 2019 2:45 pm    Post subject: Reply with quote
many thanks Gents Thumb
2005 997 C2S
Sport Chassis. LSD.
