996 : 1997-2005 43
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
timbo1811
PostPosted: Fri Jan 04, 2019 8:46 pm    Post subject: front springs Reply with quote
hi all, have to replace the front springs on my C2, just watched a you tube video where this was done without the use of a spring compressor, or having to remove the strut, does this seem doable like this.
Lotus Elan, Lotus Elan +2, MGA Mk11, TR4, 230 Compressor, 320 coupe, 944, Boxster 2.7, 997.1(current), VFR 1200, CBR 1100 Blackbird
PostPosted: Fri Jan 04, 2019 9:03 pm    Post subject: Reply with quote
Its iffy at best .. if you are strong and can pull the spring / shock out from the arch / wing then its possible .. ive only ever done it this way on a Boxster and i needed help ... but im only little .
You can unwind the coil spring and wind a new one on .. a fair bit of leverage is required though .
remove/ undo the diag arm , undo the link rod and you can get the shock down a bit more to try and get it out .. you have to manually compress the shock though... plenty of masking tape on the wing .
If pasm then forget this method .
Personnely .. i dont like to risk it .
Caliper off .. arms off and take out the whole lot with the hub on it .. then change the spring ... link rod is undone at the bar not the shock end .
timbo1811
PostPosted: Fri Jan 04, 2019 10:27 pm    Post subject: Reply with quote
thanks Demort. Any advice on best place to purchase?
Alfaian
PostPosted: Sat Jan 05, 2019 8:54 am    Post subject: Reply with quote
I have a brand new set of four coil springs for a C2 that I wrongly ordered for my C2S if you're interested.
Arctic silver C2S
