997 : 2004- 71
964 : 1989-1993 5
Boxster : 1997- 21
Cayenne : 2003- 4
rickprice
PostPosted: Thu Jan 03, 2019 11:37 pm    Post subject: Bluetooth in the frunk Reply with quote
I wonder if someone can enlighten me please?
I want to fit a Bluetooth adapter for my phone and I see there are 2 or 3 after-market units that plug into the optical loom. As I see it, you have to disembowel the car to get them in. Which I get, to some extent.
Is there any reason they cannot be wired in place if the CD-changer, in the front boot? Presumably all the right wires are there; power, MOST loop, etc?
Why can it not be done this way?
Forgive the stupid, non-electrician question.
Richard
slackster
PostPosted: Fri Jan 04, 2019 12:05 pm    Post subject: Reply with quote
I've had the tooki and the dension500 units fitted on previous 9x7's and I put them in place of where the phone module was ( under the drivers seat )
I then just removed the CD changer from the loop and added the connector to link the MOST fibre loop up without it in the middle.
I think I recall that when I tried to add the tooki once and forgot I'd got the porsche phone kit in the loop the tooki just didn't work, it only sprung to life when I took the phone unit out of the loop.
it may work though.. I suppose since its easier to get to the frunk CD changer then its quicker to get it tested, assuming you can tap power down there also?
Gen I | 997 TT | Basalt Black
Gen I | 997 c2s | Atlas grey
Gen I | 987 cayman S | Atlas grey
