991 : 2011-2019 0
997 : 2004-2012 1
Boxster : 1997- 22
Cayman : 2005- 14
k11pol
PostPosted: Thu Jan 03, 2019 10:00 pm    Post subject: Terrible rattling from interior on GTS Reply with quote
I’m having some really bad vibration rattling from my passenger door. If I press against the carbon trim around the door handle it disappears but straight back as soon as I let go, It makes for a very frustrating drive. Ithought there might be something loose needing clipped back into place but it all looks fine, anyone have any ideas how to get rid of this ? Is this a warranty issue ?
Coincidentally the speaker on the same door is terrible for interference I wander if there’s a connection between the two.
pzero
PostPosted: Thu Jan 03, 2019 10:21 pm    Post subject: Reply with quote
Has the parssenger window been replaced at some point?
991.1 Carrera GTS
k11pol
PostPosted: Thu Jan 03, 2019 10:25 pm    Post subject: Reply with quote
I’ve no idea , I bought it about 3 months ago so maybe previous to my ownership.
pzero
PostPosted: Thu Jan 03, 2019 10:51 pm    Post subject: Reply with quote
Just a theory in the abscence of anything else. If the glass had indeed been smashed or broken in the past some of the fragments may have slipped into the door.
Happened to me many years ago, albeit in a different car. Very annoying.
Whatever it is I hope you manage to get it sorted.
991.1 Carrera GTS
michelin
2006 Porsche 997 Carrera 2
PostPosted: Fri Jan 04, 2019 6:56 pm    Post subject: Reply with quote
Check the markings on all the glass and compare. This should give you a good idea if it has been changed.
Current:
Porsche 981 S PDK Fully Loaded, beautiful.
Former:
Porsche 911 997.
Audi A4 B7 2.0T FSI S-Line.
BMW E36 318iS Coupe.
Ford Escort RS Turbo Series 2.
Ford Fiesta XR2 MKII.
PostPosted: Fri Jan 04, 2019 7:18 pm    Post subject: Reply with quote
If the door panel has been removed in the past then there are some hooks with a rubber bush on them .. if one of these falls out or ends up in the wrong place the door will rattle like a bitch .
There are a couple of plastic parts that can also cause noises .. both require the door card to be removed .
It certainly used to be covered by the Porsche warrenty .. cant say 100% these days but a rule of thumb is .. if it is something that has broken due to a mechanical or a material defect then its covered .
