996 : 1997-2005 43
Boxster : 1997- 13
Macan : 2014- 0
Milo72
PostPosted: Tue Jan 01, 2019 9:35 pm    Post subject: Bose Subwoofer for a Cab Reply with quote
Anyone know if these can be retro fitted? Just seen my local breakers has one but wasn’t sure if all the cables were already in place and if it would be a simple plug in....
997.1 C2S Cab Tip.
Millsy71
PostPosted: Tue Jan 01, 2019 9:48 pm    Post subject: Reply with quote
im guessing not Milo,
AFAIK these are all fibre optic cabled, so a complete retrofit would probably be needed Confused
944 22 years ago.
Now a 997.1 C4S Cabby with lots of toys..........
Whats not to love!! Smile
PostPosted: Tue Jan 01, 2019 10:49 pm    Post subject: Reply with quote
Huge job and not worth the cost v the improvements , you could get a far better amp sub speaker set up for a fraction of the cost , have a look at the thread by Ducatirob to see what he did, amazing sound system in his car Thumb Thumb but you could get a better than bose set up more easily than Rob why wanted the very best sound . I fitted a rainbow beats amp and alpine head unit and that was better than Bose and that was without adding sub and changing speakers. Thumb Thumb
Milo72
PostPosted: Tue Jan 01, 2019 11:19 pm    Post subject: Reply with quote
Thanks for the replies... Onviously not a couple of clips and a cable then Surprised
997.1 C2S Cab Tip.
icekay
PostPosted: Tue Jan 01, 2019 11:34 pm    Post subject: Reply with quote
I too subscribe to the above, the Bose setup is decent enough but not amazing, if I was looking to upgrade I would definitely go for something else.
As a side note, been 15 years since I started sampling various Bose products and still amazes me the brand is regarded as this premium audio product stuff, I suppose that just like Beats they've got some pretty good marketing skills.
2011 997 C4 GTS Cab
sp1ke
PostPosted: Wed Jan 02, 2019 12:39 pm    Post subject: Reply with quote
If you want something compact, then a few people on the forums have gone for underseat sub's from Kenwood or Focal. Depending on your car & seat positions these may not actually fit under the seats.
I've no connection to them, but this trader currently has some deals on kenwood & focal subs:
http://caraudiosecurity.com/bass-deals-active-passive-boxes-active-bass-tubes-boxes-underseat-subwoofer
Re: connections, as far as I'm aware the stock head unit uses a 15amp fuse, According to Focal's installation instructions, for a stereo with less than 25amp fuse, you'd need to use the "traditional" option for separate direct power/earth connections rather than the piggy back ISO connectors provided with their active subwoofer.
That should be simple enough with a fuse tap/piggy back from another unused slot, & then you just need to find a suitable earth, & connect the remote signal, & rca leads to your head unit.
hth
