964 : 1989-1993 6
Boxster : 1997- 18
Cayman : 2005- 12
Cayenne : 2003- 3
Macan : 2014- 1
Milo72
PostPosted: Tue Jan 01, 2019 1:24 pm    Post subject: Cold engine ticking noise.... Reply with quote
Went out and started my car for the first time in about 3 weeks and there was a ticking noise coming from the right hand side..... the blood instantly drained from me and I thought about listing a kidney on eBay to pay for the Hartech repair.
When the car came up to temperature it went away, was it just because all the oil had drained away from that side. I had a borescope about 20 miles ago and although there was slight marking, nothing significant to suggest bore issues.
Any ideas ?
997.1 C2S Cab Tip.
kas750
Reims
2006 Porsche 911
PostPosted: Tue Jan 01, 2019 1:29 pm    Post subject: Reply with quote
Probably just a lazy lifter.
The only solution is to use it more.
Milo72
PostPosted: Tue Jan 01, 2019 1:39 pm    Post subject: Reply with quote
Going for a blast this afternoon...
997.1 C2S Cab Tip.
DucatiRob
PostPosted: Tue Jan 01, 2019 9:43 pm    Post subject: Reply with quote
I had this too, it was quite noticeable after the engine was rebuilt, noise would be intermittent, usually from cold and sometimes when it was warm too! Strangely, the ticking gradually went away over the course of several months and now is gone altogether!
Mercedes CLK DD
Ducati 996
PostPosted: Wed Jan 02, 2019 7:10 pm    Post subject: Reply with quote
I was chatting to Milo about something else via pm when he mentioned this .. my basic desription of the tappets that i sent him ..
Its what we call sticking tappets .. think of 2 buckets one inside of the other that are kept appart by oil / oil pressure .. cars left for a period of time can loose some of that oil and so cause a small gap .. normally they are pressed outwards against the valve and the camshaft .
This will cause a rattle untill they refill .. as the holes are tiny then this often doesnt go away untill the car is fully warmed up.
Its a little more complicated than that but this gives a basic understanding of a tappet .
