997 : 2004- 71
964 : 1989-1993 5
Boxster : 1997- 20
Cayenne : 2003- 4
rc944
PostPosted: Sun Dec 30, 2018 4:38 pm    Post subject: is there a correlation between mileage and engine rebuilds? Reply with quote
Keen to know if there is or not based on experience rather than opinion or hearsay
i expect nature and frequency of usage will have a higher impact on engine wear but keen to draw on the experiences (not opinions) of those in the know!
997.1 gt3 or 993 c4s (pending)
964 c4 (sold)
968 cs (sold)
944 s2 (sold)
tyinsky
1997 Porsche 993 Carrera 2S
PostPosted: Sun Dec 30, 2018 5:26 pm    Post subject: Reply with quote
I don’t think there is any correlation. Mine was done at around 150k as it was leaking oil everywhere and a AA contractor put lawnmower fuel in it burning an exhaust valve. Was still running though.
While mine was being done there was another on the bench that had covered 60k-something. Personally I doubt 60k was the actual mileage on the engine.
PostPosted: Sun Dec 30, 2018 7:09 pm    Post subject: Reply with quote
Nope.
Main cause is oil leaks which can be a partial strip depending on whats leaking .
Im kinda in the know but 993 is not my specialist area .. although i can always ask the guys at work that it is .
rc944
PostPosted: Sun Dec 30, 2018 8:01 pm    Post subject: Reply with quote
great thanks keep it coming
964 c4 (sold)
968 cs (sold)
944 s2 (sold)
ras62
PostPosted: Mon Dec 31, 2018 10:28 am    Post subject: Reply with quote
These engines can have severe wear and still run fairly well. Personally I wouldnt trust miles as a key indicator for two reasons. 1 these cars are easy clocked 2 you dont know where the miles were done. Motorway with a cool engine or sat in town with the oil cooler fans working. The latter induces wear much quicker.
Its almost certain most cars will have worn exhaust valve guides. Oil leaks are common and some need the motor apart to remedy. Perhaps the best indicator of when to rebuild is oil consumption. If its more than a liter in 800 miles of fairly hard driving I would rebuild.
wozy
PostPosted: Mon Dec 31, 2018 1:19 pm    Post subject: Reply with quote
I can only go off personal experience.
Mine is just about to touch 150K miles. She pulls like a train, and this last summer in temperatures hitting 40 plus degrees she took me to
Italy and back, that’s over 2.5k miles and I doubt she used 250ml of oil the whole trip, yet I took 3 litres (just in case).
If the paperwork is there, I’d be looking at clutch changes in a 993s life. I’ve known these to be replaced at 30k mile intervals, one I viewed at 95k miles was on its fourth. Mine is still on its original.
Clutch replacement in my eyes at lower miles generally means more town stop start traffic, and that’s never as a good for an engine as all day on a free flowing road or motorway.
I’ve heard of a 180K took apart for rebuild because of minor leaks, and other than gasket fails the rest was all within tolerances.
Valve stems pops up its ugly head sometimes and I understand this as there’s much in common with the previous 964. However I’ve not seen a 993 smoke which is a sure sign of these failing, and mine def does not.
Porsche Cars of Great Britain launched the 993 in the UK in early December 1993 registering 12 x UK cars on the 6th & 7th of that month; mine is one of them.
993 C2. MBM. C4 mounts, RSRs, RS Short shifter. RS steering wheel. FSDs & M033s
Previous 2.7S, 3.2, 964 and 968CS
Endoman
PostPosted: Mon Dec 31, 2018 9:52 pm    Post subject: Reply with quote
170k and she's been cosseted. Oil and filters changed more than neccesary probably. Never wassed until fully warm (and wassed often). No smoke but a bit leaky (being sorted). I'm only the second owner, early life was OPC regular service but the clutch had gone at 30k. Interior reeked of Chanel when I got it, easy to work out.
The valve guide wear is a mystery to me seems to be an obsession in the States perhaps related to the SAI system.
20 years plus of evolution with teutonic attention to detail, but if you buy a pup then it can be a very expensive nightmare.
tyinsky
PostPosted: Wed Jan 02, 2019 2:14 pm    Post subject: Reply with quote
Endoman wrote:
...the clutch had gone at 30k. Interior reeked of Chanel when I got it, easy to work out.
KP964
Watkins Glen
PostPosted: Wed Jan 02, 2019 5:41 pm    Post subject: Reply with quote
964 is on 275k miles at the moment , no leaks or heavy oil consumption, used every day, still strong as ever and reliable , top end rebuilt at 95k
Stone Grey Metallic 964 C4
Guards Red 964 C4 sold
Tobesetc
PostPosted: Thu Jan 03, 2019 12:37 pm    Post subject: Reply with quote
Clutch replacement in my eyes at lower miles generally means more town stop start traffic, and that’s never as a good for an engine as all day on a free flowing road or motorway..
Really good point about clutch replacement as an indicator (although you never know you have all the receipts). Clever point, probably applicable to all used cars.
993 C4, Coupe '94 manual
Previous - '03 986 Boxster S
PostPosted: Thu Jan 03, 2019 2:22 pm    Post subject: Reply with quote
c90k first and only clutch on my 964. Still going strong at 130k miles when I sold it Thumb
Note: If there's a dark circular mark on the rear shelf this usually indicates the presence of a trilby so expect several clutch replacements to have been undertaken what
