964 : 1989-1993 6
Boxster : 1997- 18
Cayman : 2005- 12
Cayenne : 2003- 3
Macan : 2014- 1
DR BAL
PostPosted: Fri Dec 28, 2018 11:40 am    Post subject: 997 cab rear window felt strip Reply with quote
Hi all
Have a 997 C4S Cab and the rear quarter window felt strip is worn has
Patch’s of rubber where the felt is missing can this trim piece be easily replaced OPC wants to replace the whole window at a cost of 500 quid
Regards
Bal
PostPosted: Fri Dec 28, 2018 4:31 pm    Post subject: Reply with quote
I assume you mean no.2 here ?
https://www.deroure.com/diagrams.asp?TBL=2872&MAK=3&MDL=26&SMA=0&SMO=0&ST=&SC=0
Its available seperatley so in theory it can be replaced .. i have a feeling it would need the rear window removing though and thats not much fun on a cab .
Its not a job ive done so im afraid i would need to look at an actual seal to see if it could easily be replaced .
DR BAL
PostPosted: Sat Dec 29, 2018 10:41 am    Post subject: Reply with quote
That’s the part it looks like it’s glued to the glass
And isn’t that easy to remove so may be easier to replace the glass
