997 : 2004- 74
996 : 1997-2005 34
Boxster : 1997- 18
Cayman : 2005- 14
JayG60
PostPosted: Thu Dec 27, 2018 4:56 pm    Post subject: FOR SALE - A selection of 997 3.8s engine parts Reply with quote
Having had a good sort out in the garage I now have the remaining parts of my 997 3.8s engine for sale
Complete cam and followers etc.. spares. Everything in the picture £450
Pair of 3.8s cylinder heads £1600
Pair of 3.8s rocker covers £250
Bank 4,5,6 casing. Minor damage around cylinder perfect for refurb. £500
Oil level sensor £30
Crank pulley (no damage) £100
Air con pump £100
Power steering pump £75
Bracket and belt tensioner £50
Throttle body £75
Sump plate with windage plate £75
Ideally collected from Wilmslow in Cheshire but can post at cost
 Filesize:  478.13 KB
 Viewed:  1052 Time(s)
 Filesize:  418.71 KB
 Filesize:  470.83 KB
 Filesize:  671.98 KB
 Filesize:  356.62 KB
 Filesize:  356.11 KB
 Filesize:  487.67 KB
 Filesize:  542.1 KB
 Filesize:  559.85 KB
 Filesize:  596.22 KB
MarkGolf
PostPosted: Sun Dec 30, 2018 7:56 pm    Post subject: Reply with quote
Hi Jay,
You don’t happen to have this plastic vacuum pipe in food order so you? No idea where it goes, it just appears behind the snorkel on the air intake and joins to a little solenoid on the left of the intake manifold.
Mine has split like the picture..
Mark
Current fleet
1991 964 Carrera
2005 997 Carrera S
2008 957 Cayenne GTS
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
1995 VW Golf VR6 3.0
