997 : 2004- 71
996 : 1997-2005 36
Boxster : 1997- 25
Whitehorse
PostPosted: Tue Dec 25, 2018 10:59 pm    Post subject: Failure Oil Level Indicator - Oil Tempp Gauge Failure Reply with quote
Hello All,
My 07, Targa 4 has just displayed "Failure Oil Level Indicator" and "Oil Temperature Gauge Failure" on start up. It was serviced less than 400 miles ago and sounds quiet and there is no smoke etc. The car has sat outside for about 6 weeks since it was last used.
Any ideas, are these the same sensor or same wiring?
Thanks in advance WH
PS Merry Christmas
Slate Grey 997 Targa 4
Magic919
PostPosted: Wed Dec 26, 2018 7:48 am    Post subject: Reply with quote
A quick search shows a shared sensor. This kind of failure is pretty common. My 996 had the oil pressure sender fail, which is a bit scary. Would work again after a restart.
997.2 C4S PDK
PostPosted: Wed Dec 26, 2018 5:43 pm    Post subject: Reply with quote
Same sensor .. green arrow on the image ..
No chance of mice were you park it ?
Its the sort of place they build nests is all and they will also chew through the knock sensor wiring which is the pink arrow .
 Filesize:  68.44 KB
 Viewed:  1003 Time(s)
Whitehorse
PostPosted: Sat Dec 29, 2018 2:40 pm    Post subject: Reply with quote
Thanks for the replies.
Ahh, that would explain why both are out..
Mice eh! No but we do have rats as we're near the river.
Is it an easy job, looking at the sensor its very long, does it just lift out?
PostPosted: Sat Dec 29, 2018 4:16 pm    Post subject: Reply with quote
Not a simple job to replace im afraid .. as you say its long and you cant bend it .. im pretty sure you have to remove the inlet mainifold on that side to get it out .. been a long time since ive done one im afraid .
rats dont tend to nest on engines so it wont be that .. ive seen plenty of mice nests though over the years hence i always mention it .
Whitehorse
PostPosted: Sat Dec 29, 2018 9:25 pm    Post subject: Reply with quote
Thanks again, I'll take a look tomorrow.
