997 : 2004- 74
996 : 1997-2005 34
Boxster : 1997- 18
Cayman : 2005- 15
DucatiRob
PostPosted: Fri Dec 21, 2018 9:14 pm    Post subject: PASM Delete Reply with quote
Anyone fitted coil overs to replace PASM shocks and know a way to do this other than have it coded out by an OPC? I know Ohlins and I think KW, do a PASM delete kit that appears to be what looks like a capacitor or other electronic component that connects to the PASM lead, but £400 Surprised
Mercedes CLK DD
Ducati 996
Mini-Me
PostPosted: Sat Dec 22, 2018 4:39 am    Post subject: Reply with quote
Bilstein Damptronics coupled with DSC module is a great way to go. IMHO. Cool
2007 Carrera S
2006 Cayman S
Magic919
PostPosted: Sat Dec 22, 2018 6:28 am    Post subject: Reply with quote
Get it coded out somewhere other than an OPC.
997.2 C4S PDK
Cy00
PostPosted: Sat Dec 22, 2018 12:08 pm    Post subject: Reply with quote
any indy shop that has a PIWIS or a PIWIS clone can disable the pasm. Dont pay the dealer a lot of money to do it. Takes about 10 mins if they go slow, 20mins if they go slow + dont know what they are doing
DucatiRob
PostPosted: Sat Dec 22, 2018 7:21 pm    Post subject: Reply with quote
Thanks, that's probably what I will do. Will investigate what makes up the electronicery bits that Öhlins sell as would prefer a plug and play solution. I am sure it is just a capacitor or something, google Typing
Mercedes CLK DD
Ducati 996
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Thu Dec 27, 2018 4:03 pm    Post subject: Reply with quote
Fair enough Rob, but you'll find for most Indies that's £20 max in the tea and biscuits fund.
If you're ocd you might also need to swap the PASM /PSE/SPORT/Spoiler control switches
DucatiRob
PostPosted: Thu Dec 27, 2018 6:50 pm    Post subject: Reply with quote
£20! Bargain, if I can get someone to do it for that will be happy! I wonder why Ohlins and Eibach sell PASM delete kits for £400 Dont know
Mercedes CLK DD
Ducati 996
isysman
PostPosted: Thu Dec 27, 2018 7:24 pm    Post subject: Reply with quote
I did this. Pull the fuse to the PASM!
Actually can't remember exactly but we didn't need the kit. Fuse plus uncoding I think.
911 GT2RS Build & 981 Boxster S
Sold ~ 987 Boxster S 3.4, 997.1 3.8 Cab, 987 3.2 Boxster S, 986 Boxster 2.5
isysman
PostPosted: Thu Dec 27, 2018 7:40 pm    Post subject: Reply with quote
This is from my build thread
http://911uk.com/viewtopic.php?t=97438&postdays=0&postorder=asc&start=880
Quote:
Suspension arrived quickly however another issue. The Ohlins comes with a PASM cancellation kit which tells the car to not throw up a fault when you press the PASM button. However Ohlins said it was on back order and wouldn't be ready for 1 month. I was due to leave for a trip to Monaco in a few days, so some more research and we decided to try to pull the PASM fuse and deactivate it in PIWIS - it worked! So if you are buying this kit and your car has PASM, don't spend £400 on a PASM cancel kit, just follow this instruction.
The car looks amazing and it feels the last part of the puzzle has been inserted. The car feels finished to me now. I will add more parts such as a roll cage but mostly just little things now. In the next article, I'll talk about how the car drives now it's complete. It's quite a contrast!
DucatiRob
PostPosted: Thu Dec 27, 2018 10:37 pm    Post subject: Reply with quote
Sounds like the way to go, plus saving £400 I don't need to spend Thumb
Mercedes CLK DD
Ducati 996
Chateauneuf
PostPosted: Sat Dec 29, 2018 7:57 am    Post subject: Reply with quote
How do the Bilstein B16s compare price wise to the Ohlins? I had the same conundrum and opted for the Bilsteins so I could keep the button.
DucatiRob
PostPosted: Sat Dec 29, 2018 9:08 pm    Post subject: Reply with quote
I think the B16's are a few hundred quid less and the Damptronics are about the same, some good discounts on the Damptronics at the moment!
Mercedes CLK DD
Ducati 996
ninenineseven
PostPosted: Wed Jan 09, 2019 10:02 am    Post subject: Reply with quote
I've just done this and can confirm it works.
Code it to not fitted with Durametric Pro (or similar) and pull the 15amp fuse, it's #9 row C Thumb
DucatiRob
PostPosted: Wed Jan 09, 2019 9:57 pm    Post subject: Reply with quote
Thumb Might just buy one of these! Will always come in handy!
Mercedes CLK DD
Ducati 996
ninenineseven
PostPosted: Thu Jan 10, 2019 7:17 pm    Post subject: Reply with quote
If you need to borrow durametric to do this pm me your address and I'll send you mine so long as you post it back Thumb Laughing
DucatiRob
PostPosted: Thu Jan 10, 2019 8:16 pm    Post subject: Reply with quote
That is really kind of you, thank you! If I don't buy one I will certainly take you up on your offer Thumb
Mercedes CLK DD
Ducati 996
