996 : 1997-2005 40
Boxster : 1997- 13
Cayman : 2005- 10
Macan : 2014- 0
Les Richards
PostPosted: Wed Dec 19, 2018 1:01 pm    Post subject: Mirror Switch 993 613 241 00 Reply with quote
My mirror switch (switchover l/r and adjustment) appears to be on the way out.
Does anyone know if one from another model can be used in its place?
It seems the switches on some later models have much the same part no. except for the first three digits which seem to reflect the model.
Could it be a VW part?
Bit of a long shot but thought I'd ask.
Thanks.
Les Richards
993
Polar Silver
5152 MU
Endoman
PostPosted: Wed Dec 19, 2018 11:35 pm    Post subject: Reply with quote
I bought a replacement a while ago only to find it was worse than the old one. So I cleaned up the terminals stuck the old one back and it's been fine.
Les Richards
PostPosted: Thu Dec 20, 2018 8:42 am    Post subject: Mirror Switch 993 613 241 00 Reply with quote
Suspecting that the terminals inside might be tarnished as the switch doesn't get that much use I removed it and toyed with the idea of easing back the fixing lugs and opening it up.
But mindful of past experiences of springs and levers and not being able to reassemble, I sprayed copious amount of WD40 into the switch, worked the buttons for a good few minutes and left it over night.
It now seems to be working much better. I have up/down, left/right on both sides which I didn't have before.
I take your point that used parts often aren't any better than those they replace and I don't feel I want to pay OPC prices.
So, for the moment at least I'll say that's a job done (but I may still try and source another one...).
Cheers.
Les Richards
993
Polar Silver
5152 MU
