997 : 2004- 71
996 : 1997-2005 36
Boxster : 1997- 25
beejay993
PostPosted: Mon Dec 17, 2018 8:54 pm    Post subject: PSE overhaul query Reply with quote
Having just removed the original PSE from my 4s due to corroded seams on the silencer,I now plan on welding up the seams to try and get another good few years out of it. The problem I have is that a few years ago Porsche removed the exhaust due to a chattering sound, which was found to be the PSE flap valves. The cure for this was to weld the valves in place with a tack on the opposite site from the actuator lever. I want to get the exhaust back to operate as it should and intend replacing the actuators etc. The issue I have is that I possibly need to replace the flapper element as I guess the spindles or bushes are worn which was causing the chattering noise. Does anyone know if you can replace the entire flap and housing ? Can you replace the bushes either side of the flap ?
I’m hoping someone else had had similar issues and there is a fix for this problem.
993 C4s - Midnight blue
996 C4s - Arctic
997 Gen 1 Turbo
997 GTS
997 Turbo S - GT Silver
996 C4s - Polar
Johnd52
2011 Porsche Cayman 987
PostPosted: Mon Dec 17, 2018 9:14 pm    Post subject: Reply with quote
It sounds as if the cost of resurrecting these units could easily be more than the cost of replacing them. They have been welded shut for a few years, they rattled before that. Did they actually work?
I would be looking to see if you could find and fit replacement units, or even just bite the bullet and fit a new top gear alternative.
2015 Cayman GTS. No more PDK but still red.
