996 : 1997-2005 43
Boxster : 1997- 13
Macan : 2014- 0
dvaughan79
PostPosted: Sun Dec 16, 2018 12:34 pm    Post subject: Porsche 964 Side Sill Rubber Replacment Reply with quote
Hi Everyone,
I'm looking to replace the side sill rubber and shark fin rubber as they seem to have shrunk.
Does anyone know of a guide to begin the strip-down?
Many Thanks
Gazc2
PostPosted: Sun Dec 16, 2018 1:20 pm    Post subject: Reply with quote
www.911uk.com/viewtopic.php?p=423914
also try the 964 section on Rennlist should be some pics of the process, pretty straightforward you will need to replace some of the poppers and clips as the tend to break during removal
2007 997 Turbo & 924s in progress
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
dvaughan79
PostPosted: Sun Dec 16, 2018 7:01 pm    Post subject: Reply with quote
Thanks Gaz
paul284pt
PostPosted: Sun Dec 16, 2018 9:04 pm    Post subject: Reply with quote
I did it a while ago, there should be enough here for you from my thread "Plan B"
http://911uk.com/viewtopic.php?t=82941&postdays=0&postorder=asc&start=620
All parts are available from your OPC. Don't forget to buy new plastic clips male & female when you replace the rubber seals, you'll break a few.
Cheers,
Paul
1980 - 84 924 Turbo with mods. (ex Tony Dron - 12th at Le Mans 1980 with works 924 Carrera Turbo).
1984 - 89 911 SC (1982)
1989 - 93 911 Carrera Sport (1989)
2010 - 964 Carrera 2 (1990) Redtek 3.8RSR
2012 - 14 Porsche Cayenne (2012)
2015 - 17 Porsche Cayenne Diesel S (2015)
2017 - 18 Macan Turbo Performance Package (2017)
2018 - 991.2 Carrera 4 GTS (2018)
