996 : 1997-2005 40
Boxster : 1997- 13
Cayman : 2005- 10
Macan : 2014- 0
Pretzel
PostPosted: Sun Dec 16, 2018 8:58 am    Post subject: Exhaust sealing rings Reply with quote
As part of checking the chassis legs involves removing the exhaust boxes, when reassembling what are the thoughts on using exhaust paste on the sealing rings or should they be assembled dry?
993 C2 Aventura
decgraham
PostPosted: Sun Dec 16, 2018 10:18 am    Post subject: Reply with quote
I've had my boxes off a few times now and have always put the rings back dry. Never had a problem.
ATB Smile
Endoman
PostPosted: Sun Dec 16, 2018 11:49 am    Post subject: Reply with quote
Yes dry, just wire brush any corrosion and don't lose them they are daft expensive to replace. Plenty of lube and heat on the nuts for the heat shields and stays it's a real pia if you snap those studs.
ras62
PostPosted: Sun Dec 16, 2018 12:17 pm    Post subject: Reply with quote
Dry, tighten clamp then a few good bangs with a hammer and tighten again.
