997 : 2004- 70
964 : 1989-1993 5
Boxster : 1997- 19
Cayenne : 2003- 4
Chigster
PostPosted: Sun Dec 16, 2018 6:25 am    Post subject: Misfire - Again! Reply with quote
Hey folks - it’s me again.
I’ve had a misfire issue before and had changed coil packs over the summer and then the solenoids less than 2 months back. Car has been running like a dream - smooth and crisp.
Then yesterday as I was leaving a froend’s place got a really strong misfire and vibration followed promptly by the check engine light. 😞. Nursed it home but definitely didn’t feel right although the vibration stopped once it had warmed up.
Car’s been parked up outside and hasn’t been properly driven for a while and it was cold and very wet yesterday but that shouldn’t be a contributing factor should it? Don’t have a fault reader but trying to work out what it could be as feel I’m running out of options.
Many thanks !
Martin996RSR
PostPosted: Sun Dec 16, 2018 9:23 am    Post subject: Reply with quote
There's a bunch of stuff it could be, wiring loom fault, intermittent crankshaft position sensor fault, coil pack/plug fault, injector fault.
Invest in a decent fault code reader and you'll save yourself a huge amount of guesswork. Where are you? If you're nearby to me then I'll pop over and plug in mine if you like.
Chigster
PostPosted: Sun Dec 16, 2018 9:27 am    Post subject: Reply with quote
Thanks Martin, I’m in Harrow NW London.
Martin996RSR
PostPosted: Sun Dec 16, 2018 1:28 pm    Post subject: Reply with quote
Bit far I'm afraid, I'm in Fleet, Hampshire. I'm sure there are other forum member closer to you who could help you out though.
thecarfixer
PostPosted: Sun Dec 16, 2018 4:10 pm    Post subject: Reply with quote
I'm based in NW London with a PIWIS if it helps..
Chigster
PostPosted: Sun Dec 23, 2018 5:45 am    Post subject: Re: Misfire - Again! Reply with quote
Many thanks !
Update: got Error Codes read and it was a misfire on cylinder 5. Mech suspects a sticking tappett. Cleared it and hasn’t come back but will drive it over the next few days and see if it reappears.
