996 : 1997-2005 43
Boxster : 1997- 13
Macan : 2014- 0
Ffmygale
PostPosted: Sat Dec 15, 2018 10:04 am    Post subject: Tiptronic to manual conversion (and vice versa)... advice Reply with quote
Can anyone give me some advice here please?
I already own a manual 964 c4 cab and have found a 964 c2 tiptronic I’d like to buy. I’m thinking of sitting the two side by side and swapping the manual box with the tip. I appreciate a few people have done the conversion to manual, but has anyone done it like this, a straight swap between two cars?
Is it a straightforward swap? Are the boxes interchangeable or are there other complications? What issues should I be aware of?
RobIpswichUK
1994 Porsche 993 Carrera 2
PostPosted: Sat Dec 15, 2018 10:45 am    Post subject: Reply with quote
Someone will be along shortly who knows more than me, but not sure you can just switch the gearbox between a C2 and C4 due to the drivetrain (4wd vs 2wd) you'd probably have to take all the running gear along, and then you'd hit problems.
Rob
'94 C2 Iris Blue (+ White Stripes!) Cup 2's, Big Ovals, FSD's/Eibach, OMP Strut Brace, 200 Cell Powerspeed Cats, 1.75" Hollamby Exhaust bypass, Carnewal FPB.
Mercedes SL (R230 lowered + AMG wheels)
Range Rover Sport V8 (L320 chipped)
TT Roadster (standard - wife’s daily!)
W211 E320CDI Barge (must not forget - NEED TO SELL!)
E91 320d SE Touring (must not forget - NEED TO SELL!)
Gazc2
PostPosted: Sat Dec 15, 2018 10:50 am    Post subject: Reply with quote
Not straight forward due to the electronics on the tip and the C4, not worth it imho a lot of hassle, Head over to the 964 section on Rennlist the boys there will give you some good advice.
2007 997 Turbo & 924s in progress
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
jev911uk
PostPosted: Sat Dec 15, 2018 11:47 am    Post subject: Reply with quote
You are possibly trying the most tricky of all swaps.
C4 Manual into C2 tip to make a C2 = nightmare and will devalue both cars
C4 gearbox to C2 gearbox = not easy / requires custom parts
C2 Tip to C2 manual = not too bad if you find a C2 box
The least worst option would be to put all the C4 stuff into the C2 and make it a C4 but that seems rather longwinded and it remains a C4.
Probably easier to put the coupe roof onto the cab Smile
Ffmygale
PostPosted: Wed Dec 19, 2018 7:43 am    Post subject: Reply with quote
Thanks all. I appreciate your advice and it looks like the sensible thing to do is forget that idea!
PostPosted: Wed Dec 19, 2018 11:55 am    Post subject: Reply with quote
