996 : 1997-2005 43
Boxster : 1997- 13
Macan : 2014- 0
Rojdog
PostPosted: Fri Dec 14, 2018 11:03 pm    Post subject: Rear anti roll bar Reply with quote
Is it normal that you can move the rear anti roll bar by hand side to side?
drop links seem smooth with no knocking on both sides when removed but was surprised the bar itself could be moved with relatively little force?
anyone have a part # for the bushes?
PostPosted: Sat Dec 15, 2018 4:46 pm    Post subject: Reply with quote
Im not sure which part you mean im afraid .. can you see it in the picture below or perhaps this link to a parts sight ..
https://www.deroure.com/diagrams.asp?TBL=2821&MAK=3&MDL=26&SMA=0&SMO=0&ST=&SC=0
 Filesize:  83.51 KB
 Viewed:  575 Time(s)
Magic919
PostPosted: Sat Dec 15, 2018 6:00 pm    Post subject: Reply with quote
I’d presume it’s what we call an anti-roll bar https://www.deroure.com/diagrams.asp?TBL=2823&MAK=3&MDL=26&SMA=0&SMO=0&ST=&SC=0
997.2 C2S PDK
997.2 C4S PDK
Rojdog
PostPosted: Sat Dec 15, 2018 8:01 pm    Post subject: Reply with quote
sorry yes rear anti roll bar, the rear one has about 5mm play side to side.Easily movable by hand whereas the front is solid. Wondering if it the source of a bit of low speed clunking.
PostPosted: Sat Dec 15, 2018 8:45 pm    Post subject: Reply with quote
I doubt it will be the noise you have .. the roll bar has fixed stops so new bushes if you have play there is a good idea but again i doubt its the cause of a noise .
The most common noise would be the diagonal arms
Best description would be a .. bonk ... bonk bonk over bumps in the road .. if very loud then link rods .. but you can easily feel for play in these whilst you cant in the diag arms .
At the end of the day though .. you shouldn,t have sideways play in the roll bar .
Rojdog
PostPosted: Sat Dec 15, 2018 9:05 pm    Post subject: Reply with quote
Thanks demort new bushes it is then. I've just changed my top mounts and checked all the joints I could while the damper was out and found nothing. So it's pointing towards diagonal arms as you said. I have a trip to centre gravity booked on the 5th of Jan so may wait and see, maybe they can confirm a definite diagnosis
