991 : 2011-2019 0
997 : 2004-2012 1
Boxster : 1997- 22
Cayman : 2005- 14
blue2
PostPosted: Fri Dec 14, 2018 8:56 pm    Post subject: ssk? Reply with quote
been driving my 1st 997 for half a year now & still loving it. the 1st thing i noticed when i took it for a test run prior to handing over my dosh was the short throw of the gear stick. the seller didnt mention anything about a ssk but i want to know. has anyone got measurements of the throw on a standard carrera 997 so i can compare.
PostPosted: Fri Dec 14, 2018 9:54 pm    Post subject: Reply with quote
Just pop the cover off and look.
Thefinn
PostPosted: Sat Dec 15, 2018 12:15 am    Post subject: Reply with quote
Check your option codes as well
997.1 C4S CAB
TonyC911
PostPosted: Sat Dec 15, 2018 8:28 am    Post subject: Reply with quote
SSK is a relatively easy retro fit, but double check your build sticker on the inside of your service book, it is option code XCZ.
2012 Carrera S - Agate Grey / Pebble
Ex 2007 Carrerra S
Ex 2005 Boxster S
Ex 2003 Boxster 2.7
Ex 1998 Boxster 2.5
moonigan
PostPosted: Sat Dec 15, 2018 3:36 pm    Post subject: Re: ssk? Reply with quote
Taken from Rennlist, I found them to be pretty much bang on: https://rennlist.com/forums/997-forum/681327-porsche-short-shifter-installed-today.html
I took the measurements from the Trip Button to the center line (that goes side to side) on the shift knob. I measured the shifters in 3rd gear and 4 gear. Here are the results:
.......................................................[Stock Shifter..... Short Shifter
3rd Gear distance from Trip Button........ 4.125 inches........4.750 inches
4th Gear distance from Trip Button........ 9.000 inches........8.250 inches
Total "throw" distance from 3rd to 4th... 4.875 inches........3.500 inches
Total reduction in "throw" is 1.375 inches, which is a 28.2% reduction.
